Got my new monitor. It's great, really really like it, but I can't stand the squashed look (1920x1080) compared to my older monitor (1920x1200).
Anyone else feel the same way? Do you get used to it?
¬_¬
16:9 is horrible on the desktop and even worse on laptops.
If you have to go up a monitor size to compensate for the aspect ratio then that just suggests that there is a problem with 16:9.
I’ve never understood the better for movies argument. It’s rare to get film that’s actually 16:9 so you end up with black bars top and bottom anyway.
This is definitely not a case of the consumer dictating change, it is being forced upon us. Clippa got it spot on, 16:10 just feels right because it is nearly exactly the golden ratio making it the most aesthetically pleasing, not too narrow not too wide.
everything runs natively with better FOV.
If a port is bad enough that it doesn't have a 16:10 option, then you can almost guarantee that the fov will be the same as the console version.
For those who don't like 16:9 monitors, have you tried 27" models?
