Gah not enough power?!
21 Oct 2002
Just setup my new rig with a Antec 500W Earthwats PSU that came with my Sonata. However it appears there is not enough power for my graphics card, what do i need?
Im running it with a Gigabyte UD3R / i7 920 / OCZ Repear DDR3 / 150GB Raptor / 1tb seagate / DVDRW
The graphics card in question is an Asus Glaciator 4870 1Gb.. needing two pcie connectors.
Pointers appreciated!
Thanks
Not running the i7 at anything other than stock as its a brand new build.
Both plugged in from the cresset indicators it definately seems likes its the power .. i shouldve just added a PSU to my order when considering doh!
Ok .. the depression set in way too early there!! Its booted. The culprit, i had not plugged in the second motherboard connector. Booting now, i still think i may have to redress the power situation but for now its working.
A lesson in dilegent building. Thanks chaps
It's always good when it's a easy mistake to rectify :)
Your PSU will be fine unless you start heavily clocking the i7.
btw if your in doubt , get a power meter that plugs into the mains, shows the watts , amps used etc
ie google Plug-In Mains Power and Energy Monitor
Happy days indeed, ill def take a look at that. Would be interesting to see how much the PC actually punts towards the electricity bill.
The local PC shop wanted £100 for the new PSU .. id rather buy it way cheaper at OcUK if need be. Money saved and a working PC ;];]
Glad you've got it working now.
One of my Antec cases came with a DOA PSU, it went in the bin and bought a nice Corsair one for it.
Just to sort of close this off, ive now tested the setup. The 500W PSU is ok to run Windows and games in low resolutions however when run under real load the PSU very quickly cant supply enough power to the Graphics card and the whole machine crashes.
Going to order a new PSU on Monday, going to go for the http://www.overclockers.co.uk/showproduct.php?prodid=CA-030-OC&groupid=701&catid=123&subcat= unless there is a better alternative. Or should i go crazy and future proof myself with a 900-1000W PSU?
i had the Sonata case and the Earthwatts 500 PSU. The issue for me was the amps on the 12v rail not being high enough rather than the wattage available
