Turned my comp off this morning to go to work, came back and my monitor won't display anything, the light just blinks on and off.
It is the Viewsonic in this post: http://forums.overclockers.co.uk/showpost.php?p=13008824&postcount=2769
Anyone have any ideas about what to do? If it really is dead, I am screwed beyond anything, as I can't afford my new machine and a monitor.
Hmm. Found a temp fix. If I boot the comp with the Viewsonic unplugged, I can then plug the Viewsonic in and set it up like that. Can't find out how to reset my dual screen though. I usually have the Viewsonic as my primary, then the CRT as a secondary but not with the task bar extended across both; I don't have that choice in this nVidia manager!
