Right, a friend of mine is on O2 and uses the standard O2 router. I want to access the router stats (Line attenuation etc) and cant seem too. Have tried logging in as "SuperUser" and "O2Br0ad64nd" and this didnt work. Any ideas?
To ensure that your O2 Broadband always performs at the highest level, we occasionally carry out updates on our O2 Wireless boxes.
That’s why we’re writing to you to let you know that over the next few days, we're going to update yours. You’ll see your O2 Wireless box turn itself off and back on again, it’ll take around 30 seconds.
These updates will increase the security of your O2 Wireless box.
There are two changes we need to make you aware of:
Password to access the Router
We’re going to set up a password to protect the settings on your O2 Wireless Box. You don’t need to do anything. You’ll only need it if you want to change the settings. (In most cases, you’ll probably never need it.) The password is the serial number of your O2 Wireless Box.
You might find that it takes longer to access the settings pages on your router at http://o2wirelessbox.lan, this is because of the new security features we’ve put in place to protect you online.
Wireless Network Name
If you ever have to reset your wireless box, it will set up a new wireless network name to increase the security of your O2 Wireless Box. You don’t need to do anything to make this happen either.
If you would like to see more information around this, here's where you can find it here
Felix Geyr
Head of O2 Home and Broadband
Uptime: 0 days, 9:47:22
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,204 / 3,241
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 0.00
Output Power (Up/Down) [dBm]: 12.0 / 15.0
Line Attenuation (Up/Down) [dB]: 27.0 / 48.5
SN Margin (Up/Down) [dB]: 7.0 / 10.0
Vendor ID (Local/Remote): TMMB / BDCM
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 34 / 0
FEC Errors (Up/Down): 70 / 1,177,940
CRC Errors (Up/Down): 70 / 11,239
HEC Errors (Up/Down): 35,895 / 8,453
Uptime: 0 days, 0:00:50
Bandwidth (Up/Down) [kbps/kbps]: 1,217 / 7,376
Output Power (Up/Down) [dBm]: 12.0 / 17.5
Line Attenuation (Up/Down) [dB]: 26.5 / 47.5
SN Margin (Up/Down) [dB]: 7.0 / 6.5
Error Seconds (Local/Remote): 0 / 0
FEC Errors (Up/Down): 7 / 0
CRC Errors (Up/Down): 7 / 0
HEC Errors (Up/Down): 36,953 / 0
