Purchased a 4080 from here and the fans make a very odd noise at any level, it sounds like coil whine or a fridge humming but I know its not coil whine from using msi afterburner, from 0 rpm in the desktop I set it to the min of 30% which is around 1100 and it starts as soon as the fans start spinning, changing the fan speed does not seem to change the pitch or make it any better, its quite audible, seems to be all 3 of them making the noise, I sit 7ft away from my tv. Never used gainward before so not sure if its just their build quality or what. Nothing is blocking or obstructing the fans and they look to be sitting flush from what I can see.
