Hi Guys,
Thread posted previously 25/08/09, reposted due to some previous confusion with me using these cards in Crossfire, which I'm not, they are used seperately.
Basically I own two 4870x2 cards, I purchased the Gainward first which now appears to be faulty, showing and using only one core. I then purchased a Sapphire to replace it after Gainward refusing to replace it to start with. Now the Gainward card itself appears to work fine, but it only uses one of the two cores, this is clearly visible in GPU-Z saying Crossfire is disabled and from the low 8k performance in 3DMark Vantage. GPU-Z on the Sapphire card detects two GPUs and gets around 11500 (CPU limited) in Vantage.
After trying loads of drivers, different operating systems and making sure Catalyst A.I is enabled I assumed that the card is faulty, my guess being that the bridge chip is faulty. So I sent it to Gainward in Germany (not cheap) who to be honest I've received frankly rubbish after sales service from. Firstly they flatly refused to replace the card as it is under 1 year old, but the business I purchased it from has shut down, so I manage to get them to accept it back.
I got it back recently and according to the paperwork it was repaired, but this isn't the case, it exhibits the same problem regardless of OS (tried Windows 7 x64 and Vista x86). I e-mailed them about this and was told:
“We tested the card on two different pc for long time and we can’t reproduce your problem. The card is working fine. Please check your PC."
No communication to let me know they couldn’t reproduce the problem, they just sent it back which is not very helpful at all. I replied asking how they tested it but not heard back, think they are ignoring me know!?!
I can in fact switch the cards over, changing nothing, no changes to drivers, settings etc and the problem appears. So is there any reason anyone can think of aside from some bizarre incompatiablity that only affects a standard reference Gainward 4870x2 and my motherboard (XFX 780i) but not a standard reference Sapphire 4870x2, that would cause this problem? Or are Gainward wrong and my card is faulty?
Thanks,
Mark
Thanks,
Mark
