Gainward GeForce GTX 260 GS 1792MB Only £149.99 Inc. VAT
17 Oct 2002
Stoke
The Gainward GeForce GTX 260 graphics card rips through DirectX 10 games at blazing fast frame rates and enables realistic physical motion and massively destructible environments with NVIDIA's new PhysX. technology. And that's not all, the Gainward GeForce GTX 260 graphics card also supports extreme HD (2560x1600) resolutions, and gives your system the power of up to 216 multi-threaded processor cores, offloading the most intensive processing tasks from your CPU to your Graphics Processing Unit (GPU).
- Core Clock: 585MHz
- Memory: 1792MB GDDR3
- Memory Clock: 1998MHz (Effective)
- Memory Interface: 448-Bit
- Memory Bandwidth: 111.9GB/s
- Processing Cores: 216
- Shader Clock: 1242MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2 Dual-Link DVI-I
- SLI Ready
- HDCP Capable
- DirectX 10 Support
- OpenGL 2.1 Support
- PhysX Enabled
- CUDA Enabled
- 2 Year Warranty
Just £149.99 Inc. VAT
BUY NOW
