Gainward GeForce GTX 295 Only £378.99 Inc. VAT
17 Oct 2002
Stoke
Engineered for extreme gaming performance, the NVIDIA GeForce GTX 295 is the most powerful dual chip graphics card on the planet for gaming and beyond. Experience the hottest games such as Far Cry 2, Mirror's Edge, and Call of Duty 5: World at War at extreme HD resolutions and ultra high image quality with the power of two GeForce GTX 200 Series GPUs on a single card. And then go beyond traditional graphics with Graphics Plus and experience GPU accelerated NVIDIA PhysX gaming effects, Stereoscopic 3D gaming, video processing for transcoding HD videos in minutes to your portable video player, and lightning fast image processing using Adobe CS4.
- Bus Type: PCI Express 2.0 (Backwards compatible with PCI Express)
- Memory: 1.8GB (1792MB) GDDR3
- Core Clock: 576MHz
- Shader Clock: 1242MHz
- Memory Data Rate: 1998MHz
- Processor Cores: 480
- Shader Model: 4.0
- Texture Fill Rate: 92.2 Billion/sec.
- Memory Interface: 896-bit
- Memory Bandwidth: 223.8GB/sec.
- API Support: Microsoft DirectX 10 and lower, OpenGL 2.1 and lower for Microsoft Windows
- Display Connectors: 2 Dual-Link DVI-I, HDMI Out
- RAMDACs: Dual 400MHz
- HDCP Capable
- HDMI Capable
- Card Dimensions: 266.7mm x 95.25mm x 38.1mm
- Geforce with CUDA
- PhysX enabled
Just £378.99 Inc. VAT
BUY NOW
