Gainward GTX780Ti Phantom
14 Jul 2013
Hi Guys,
A friend of mine is considering getting this card for her rig....and I have had a good look online.
But if there are any owners of the above card...do you know if the heat goes out the back of the Pc or inside the case or both?
Charles :confused:
Have the 780 version, heat inside the case!
Also, unless getting it for cheap (sub £250) your friend would be better off looking at a GTX970 :)
