Just trying to work out what to connect here, There is an RGB cable which does plug into the uni fan controller but the Other is a fan header that does not plug into the controller. I'm guessing that just goes on the mother board fan header as the controller has no way of connecting a fan header. Simarly the case has an rgb cable that I cannot connect to this controller either.
Are there adaptor cables I'm missing or something, or should I just connect to the MB and not worry? Also can I use more than one controller to increase the number of fans supported ?
