Has anybody else had problems with their Galahad AIO?
The initial problems started with the bearing on a fan going making it incredibly loud. I contacted Lian li and they sent a replacement, but it gradually happened to the other 2 fans that came with it. They replaced all 3, but the same issue later happened with those.
So I replaced the fans with another brand and things were going smoothly until last week when I noticed my CPU was running way too hot.
Idle temps have always been a bit spikey and random with my 5800x but under load the temps would hold around 70-75c. Last week it was reaching 90c. So I re applied the thermal paste and the temps went back to normal for a few days.
However, the same thing happened again after a couple of days with the temps reaching 90c. I shut my PC down and turned it off then tipped it on its side. After rotating it back and switching it back on the temps were back to normal.
I have the radiator in the roof of my 011 so its above the pump like people recommend.
After browsing the internets, it seems like the fan failures are pretty common along with having to tilt the PC after random high temps.
Has anyone on here had the same issues ?
