Galaxy S II case and car holder advice...
5 Jan 2005
Engerland :)
just got an S2 ... I had the previous galaxy S with a Brodit active holder with a Krussel leather pouch.... worked well in my Ford Focus...
unfortunately both dont fit the S2...this time around I would like a case not a leather pouch.. and a car holder - preferably with charger ... the problem with the Brodit is it wont allow a phone with a case on....
what you guys using - particularly with an 05 (ish) ford focus.
thanks in advance.
What is this I don't even... :D
Basically I think it boils down to this:
Case: Samsung Mesh case
Mount: Nokia CR-115 (you will need to replace/trim the rubber pads to be thinner, job done).
Cheers guys.
Yep I did find that thread after I posted... And did read all the pages.
Settled on the nokia holder that mrk recommended and the case mate... And martin... Screen protectors.
Figured cheap holder and will probably do the trick.
