- 22 Mar 2014
Hi guys,
I really hope someone can help me on this one!
For the past couple of months I have been plagued with games minimising, crashing to desktop with no error messages and I'm completely fed up as I feel like I have tried everything to fix it but just can't.
I'm hoping someone on here knows how to read windows .dmp files as I have just found these today but again I don't really know what I'm looking at here! Anyways, my specs:
I have had a few blue screen crashes but at the time of writing I don't have any blue screen .dmp files for some strange reason.
Also to note I clone my gaming monitor via HDMI to a dedicated streaming machine.
The .dmp files:
Many thanks for any help I would really appreciate it! If you need anything else from me please just ask!!
Link to .zip of all .dmp files: https://drive.google.com/open?id=1hoEQUD4iQ8-X_Tz7NE0b88i9xqKHChBr
- Intel Core i7-7740X 4.3GHz (KabyLake X / Basin Falls) Socket LGA2066 Processor
- Asus TUF X299 Mark2 (Socket 2066) Intel X299 ATX Motherboard
- Corsair Vengeance 32GB (4x8GB) DDR4 PC4-21300C16 2666MHz
- Gigabyte GeForce GTX 1080Ti Gaming OC BLACK 11264MB GDDR5X
- Cprsair RM1000x PSU
- BenQ XL2720T 120Hz LED Monitor
- SteelSeries Rival 300 Black Mouse
- Corsair Gaming STRAFE Mechanical Gaming Keyboard Cherry MX Blue
- Corsair VOID Stereo Gaming Headset
- WD Green 3D NAND 240GB M.2 2280 6Gbps Solid State Drive
- OCZ 240GB SSD
- WD 1TB HDD
- Windows 10 Pro (Version 1803 OS Build 17134.286)
- Complete format of all drives and re-installation of Windows 10
- Clean wipe of NVIDIA Display Drivers with DDU in safe mode, multiple different driver versions used, same effect
- Tried installing games to different hard drives
- Ran memtest86 (passed) /sfc scannow (all passed) and bought a pro version of a driver installation program to get all drivers up to date.
- Latest BIOS is installed and has been even before I was having these problems
- Tried removing GPU and reseating + cleaning
- Monitored all hardware temps and cooling is doing well
- Stress tested to monitor hardware and nothing is overheating
The .dmp files:
Windows 8 Version 17134 MP (8 procs) Free x64
Product: WinNt, suite: SingleUserTS
kernel32.dll version: 10.0.17134.12 (WinBuild.160101.0800)
Machine Name:
Debug session time: Mon Sep 10 15:50:08.000 2018 (UTC - 4:00)
System Uptime: not available
Process Uptime: 0 days 0:18:16.000
Kernel time: 0 days 0:03:52.000
User time: 0 days 1:37:58.000
TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\oca.ini, error 2
TRIAGER: Could not open triage file : e:\dump_analysis\program\winxp\triage.ini, error 2
TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\user.ini, error 2
* Exception Analysis *
TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\guids.ini, error 2
*** WARNING: Unable to verify timestamp for dbdata.dll
*** ERROR: Module load completed but symbols could not be loaded for dbdata.dll
*** WARNING: Unable to verify timestamp for nvwgf2umx.dll
*** ERROR: Module load completed but symbols could not be loaded for nvwgf2umx.dll
TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2
GetUrlPageData2 (WinHttp) failed: 12029.
*** The OS name list needs to be updated! Unknown Windows version: 10.0 ***
FAULTING_IP:
bfvob+5a6087f
00000001`45a6087f ff5008 call qword ptr [rax+8]
EXCEPTION_RECORD: ffffffffffffffff -- (.exr 0xffffffffffffffff)
ExceptionAddress: 0000000145a6087f (bfvob+0x0000000005a6087f)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: 0000000000000008
Attempt to read from address 0000000000000008
PROCESS_NAME: bfvob.exe
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at "0x%08lx" referenced memory at "0x%08lx". The memory could not be "%s".
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at "0x%08lx" referenced memory at "0x%08lx". The memory could not be "%s".
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: 0000000000000008
READ_ADDRESS: 0000000000000008
FOLLOWUP_IP:
bfvob+5a6087f
NTGLOBALFLAG: 0
APPLICATION_VERIFIER_FLAGS: 0
FAULTING_THREAD: 0000000000002dd4
BUGCHECK_STR: APPLICATION_FAULT_NULL_CLASS_PTR_READ_INVALID_POINTER_READ_NULL_POINTER_READ_CALL
PRIMARY_PROBLEM_CLASS: NULL_CLASS_PTR_READ_CALL
DEFAULT_BUCKET_ID: NULL_CLASS_PTR_READ_CALL
IP_ON_HEAP: 000000000101157e
The fault address in not in any loaded module, please check your build's rebase
log at \bin\build_logs\timebuild\ntrebase.log for module which may
contain the address if it were loaded.
FRAME_ONE_INVALID: 1
LAST_CONTROL_TRANSFER: from 000000000101157e to 0000000145a6087f
STACK_TEXT:
00000000`32a2f830 00000000`0101157e : 00000001`41962c19 00b70001`f5a4f100 00000000`00000000 00000000`00000000 : bfvob+0x5a6087f
00000000`32a2f838 00000001`41962c19 : 00b70001`f5a4f100 00000000`00000000 00000000`00000000 00030001`f8a26010 : 0x101157e
00000000`32a2f840 00b70001`f5a4f100 : 00000000`00000000 00000000`00000000 00030001`f8a26010 00000000`00000003 : bfvob+0x1962c19
00000000`32a2f848 00000000`00000000 : 00000000`00000000 00030001`f8a26010 00000000`00000003 00000001`41962c19 : 0xb70001`f5a4f100
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: bfvob+5a6087f
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: bfvob
IMAGE_NAME: bfvob.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 5b894e40
STACK_COMMAND: ~21s; .ecxr ; kb
FAILURE_BUCKET_ID: NULL_CLASS_PTR_READ_CALL_c0000005_bfvob.exe!Unknown
BUCKET_ID: X64_APPLICATION_FAULT_NULL_CLASS_PTR_READ_INVALID_POINTER_READ_NULL_POINTER_READ_CALL_bfvob+5a6087f
WATSON_STAGEONE_URL: http://watson.microsoft.com/StageOn...402/5b894e40/c0000005/05a6087f.htm?Retriage=1
Followup: MachineOwner
Machine Name:
FAULTING_IP:
bfvob+5a6087f
NumberParameters: 2
FOLLOWUP_IP:
bfvob+5a6087f
NTGLOBALFLAG: 0
STACK_TEXT:
MODULE_NAME: bfvob
Machine Name:
Debug session time: Tue Sep 11 06:42:12.000 2018 (UTC - 4:00)
Process Uptime: 0 days 0:49:37.000
Kernel time: 0 days 0:10:31.000
User time: 0 days 4:41:47.000
*** WARNING: Unable to verify timestamp for bfvob.exe
*** ERROR: Module load completed but symbols could not be loaded for bfvob.exe
*** WARNING: Unable to verify timestamp for GfeSDK.dll
*** ERROR: Module load completed but symbols could not be loaded for GfeSDK.dll
*** WARNING: Unable to verify timestamp for poco.dll
*** ERROR: Module load completed but symbols could not be loaded for poco.dll
FAULTING_IP:
nvwgf2umx+b5b790
00007ff9`a2a7b790 4983791800 cmp qword ptr [r9+18h],0
ExceptionAddress: 00007ff9a2a7b790 (nvwgf2umx+0x0000000000b5b790)
NumberParameters: 2
Parameter[1]: 00000000000019db
Attempt to read from address 00000000000019db
DEFAULT_BUCKET_ID: INVALID_POINTER_READ
EXCEPTION_PARAMETER2: 00000000000019db
READ_ADDRESS: 00000000000019db
FOLLOWUP_IP:
nvwgf2umx+b5b790
NTGLOBALFLAG: 0
FAULTING_THREAD: 0000000000002318
PRIMARY_PROBLEM_CLASS: INVALID_POINTER_READ
BUGCHECK_STR: APPLICATION_FAULT_INVALID_POINTER_READ
IP_ON_HEAP: 000000003eb82e90
LAST_CONTROL_TRANSFER: from 000000003eb82e90 to 00007ff9a2a7b790
STACK_TEXT:
00000000`3f00f630 00000000`3eb82e90 : 00000000`0000dbaf 00000000`00000000 00000000`7a376890 00000000`00000000 : nvwgf2umx+0xb5b790
00000000`3f00f638 00000000`0000dbaf : 00000000`00000000 00000000`7a376890 00000000`00000000 00007ff9`a2a7ad66 : 0x3eb82e90
00000000`3f00f640 00000000`00000000 : 00000000`7a376890 00000000`00000000 00007ff9`a2a7ad66 00000000`7adee540 : 0xdbaf
SYMBOL_NAME: nvwgf2umx+b5b790
MODULE_NAME: nvwgf2umx
IMAGE_NAME: nvwgf2umx.dll
DEBUG_FLR_IMAGE_TIMESTAMP: 5b7be952
STACK_COMMAND: ~25s; .ecxr ; kb
FAILURE_BUCKET_ID: INVALID_POINTER_READ_c0000005_nvwgf2umx.dll!Unknown
BUCKET_ID: X64_APPLICATION_FAULT_INVALID_POINTER_READ_nvwgf2umx+b5b790
WATSON_STAGEONE_URL: http://watson.microsoft.com/StageOn...907/5b7be952/c0000005/00b5b790.htm?Retriage=1
Machine Name:
FAULTING_IP:
nvwgf2umx+b5b790
NumberParameters: 2
FOLLOWUP_IP:
nvwgf2umx+b5b790
NTGLOBALFLAG: 0
STACK_TEXT:
Machine Name:
Debug session time: Thu Sep 13 10:31:00.000 2018 (UTC - 4:00)
Process Uptime: 0 days 0:25:43.000
Kernel time: 0 days 0:06:42.000
User time: 0 days 2:05:00.000
*** WARNING: Unable to verify timestamp for bf1.exe
*** ERROR: Module load completed but symbols could not be loaded for bf1.exe
FAULTING_IP:
+aaabe2
00000002`c0844a80 4029ad42010000 sub dword ptr [rbp+142h],ebp
ExceptionAddress: 00000002c0844a80
NumberParameters: 2
Parameter[0]: 0000000000000008
Parameter[1]: 00000002c0844a80
Attempt to execute non-executable address 00000002c0844a80
PROCESS_NAME: bf1.exe
EXCEPTION_PARAMETER1: 0000000000000008
EXCEPTION_PARAMETER2: 00000002c0844a80
WRITE_ADDRESS: 00000002c0844a80
FOLLOWUP_IP:
bf1+aaabe2
00000001`40aaabe2 ?? ???
FAILED_INSTRUCTION_ADDRESS:
+aaabe2
NTGLOBALFLAG: 0
FAULTING_THREAD: 0000000000002bbc
BUGCHECK_STR: APPLICATION_FAULT_SOFTWARE_NX_FAULT_INVALID
PRIMARY_PROBLEM_CLASS: SOFTWARE_NX_FAULT_INVALID
DEFAULT_BUCKET_ID: SOFTWARE_NX_FAULT_INVALID
LAST_CONTROL_TRANSFER: from 0000000140aaabe2 to 00000002c0844a80
STACK_TEXT:
00000000`2939e9d8 00000001`40aaabe2 : 00000000`2939eae0 00000002`ba874510 bf0e9215`bf45e403 bf0e9215`bf0e9215 : 0x2`c0844a80
00000000`2939e9e0 00000000`2939eae0 : 00000002`ba874510 bf0e9215`bf45e403 bf0e9215`bf0e9215 bf318990`00000000 : bf1+0xaaabe2
00000000`2939e9e8 00000002`ba874510 : bf0e9215`bf45e403 bf0e9215`bf0e9215 bf318990`00000000 bf318990`00000000 : 0x2939eae0
00000000`2939e9f0 bf0e9215`bf45e403 : bf0e9215`bf0e9215 bf318990`00000000 bf318990`00000000 beea0267`bf226799 : 0x2`ba874510
00000000`2939e9f8 bf0e9215`bf0e9215 : bf318990`00000000 bf318990`00000000 beea0267`bf226799 beea0267`beea0267 : 0xbf0e9215`bf45e403
00000000`2939ea00 bf318990`00000000 : bf318990`00000000 beea0267`bf226799 beea0267`beea0267 00000000`2939f960 : 0xbf0e9215`bf0e9215
00000000`2939ea08 bf318990`00000000 : beea0267`bf226799 beea0267`beea0267 00000000`2939f960 00000000`00000000 : 0xbf318990`00000000
00000000`2939ea10 beea0267`bf226799 : beea0267`beea0267 00000000`2939f960 00000000`00000000 00000000`00000000 : 0xbf318990`00000000
00000000`2939ea18 beea0267`beea0267 : 00000000`2939f960 00000000`00000000 00000000`00000000 0000042c`79756fa4 : 0xbeea0267`bf226799
00000000`2939ea20 00000000`2939f960 : 00000000`00000000 00000000`00000000 0000042c`79756fa4 00000000`3f800000 : 0xbeea0267`beea0267
00000000`2939ea28 00000000`00000000 : 00000000`00000000 0000042c`79756fa4 00000000`3f800000 00000000`fd002440 : 0x2939f960
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: bf1+aaabe2
MODULE_NAME: bf1
IMAGE_NAME: bf1.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 5b69e2b3
STACK_COMMAND: dt ntdll!LdrpLastDllInitializer BaseDllName ; dt ntdll!LdrpFailureData ; ~18s; .ecxr ; kb
FAILURE_BUCKET_ID: SOFTWARE_NX_FAULT_INVALID_c0000005_bf1.exe!Unknown
BUCKET_ID: X64_APPLICATION_FAULT_SOFTWARE_NX_FAULT_INVALID_BAD_IP_bf1+aaabe2
WATSON_STAGEONE_URL: http://watson.microsoft.com/StageOn...0_0/bbbbbbb4/c0000005/c0844a80.htm?Retriage=1
Machine Name:
FAULTING_IP:
+aaabe2
NumberParameters: 2
FOLLOWUP_IP:
bf1+aaabe2
+aaabe2
NTGLOBALFLAG: 0
STACK_TEXT:
MODULE_NAME: bf1
IMAGE_NAME: bf1.exe
