Game freezes in TOCA 2 with steering wheel plugged in...
2 Jan 2004
Chesterfield
I have been happily playing TOCA 2 using my pad and I decided to give it a try with my Thrustmaster steering wheel....
I can assign the controls but the game pauses for 3-4 seconds every few seconds in the game!?!?!
I am using the latest drivers off the website and I'm on the latest patch for the game!!!
Any ideas anyone???
StevieP
Is it a force feedback steering wheel?
If so this is a known problem and there's a fix on the codemasters website.
You need to set the Toca 2.exe (or however it is named) to have high priority in taskmanger (right click on it). You can create a shortcut that does this with an entry in the target path.
This same problem also applies to Toca 3 for those suffering similar problems.
