Gamecube Component Cable Help...
4 Aug 2004
Surrey
I know this is a bit of a long shot but i don't suppose anyone on the boards knows where i could find a Gamecube component cable that costs less than the £60 imported ones on ebay?
I think i've possibly located one in a second hand store in Ipswich on the cheap but my only problem is i live nowhere near. any help would be greatly appreciated. Thanks
you're all thinking of the analogue Composite cable which came as standard with the cube, im looking for the digital Component cable which was discontinued and is now pretty difficult to get hold of.
yea that one in CEX was the one i found.. sadface. i love my trusty old cube, unless i can find someone who lives in ipswich so buy it and send it over to me then im probably a bit stuffed or will just have to make do with the horribly blurry image... damn you HD TV!
so if anyone lives in ipswich and wants to give me a helping hand?
i tried calling the branch directly to confirm they had it in stock but the only phone number for it is an internal number and the guy on the phone wasn't too happy that i called them on it lol.
I bought an Import US Cube just for this reason .. 480p goodness :)
I was under the impression that an original PAL cube with the digital output would work fine with a component cable? seems kinda pointless for them to put the output on the back only for it not to work...
