Hi all.
I have been asked by a friend to build his son a new PC for Xmas, not having build a PC for while I have a quick question.
The Kamikaze Pro Case has a split cable with VDG on it that comes from the fan controller thingy....
I'm not too sure where this cable goes on the Mobo?
As I said it is a split type cable to it goes to a 3 pin (4 holes but only 3 pins in it) and from that there is the connector that says VDG on it??
The only socket i can see on the Mobo that this cable would fit is labelled as JRAINBOW? Do I plug it in that and no need to worry about the VDG?
Any help would be much appreciated
Thanks
Thanks
