games become unplayable
24 Jun 2012
at the minute this only really happens on Prototype 2, but i can play it for a good 20/30 minutes not a single drop in FPS and runs smooth, but after that its pete tong!
FPS drop becomes completely unplayable jerking and any action that happens just might aswell give up cause its at 10FPS or less and acting like it cant handle it!
i run game booster so nothing is running in the background eating my resources,
CPU temp is 55
GPU temp is 60 which i consider normal/low on load!
i run
Phenom X2 3.0ghz (not OC'd)
4gb 1066 Ballistix DDR2
ATI Radeon 5670 HD
lost as to what the problem is cause ive tried what i consider everything to my knowledge so now i need your help lol! any ideas?? apart from upgrade my system!
Totalbisuit (a youtuber) Had the same problems and says it's a shoddy port
(How do I embed, anyone?)
You could check PC Gaming Wiki to see if they have any fixes
Use the youtube code like from your link it would be KJ5I4L_3RxY,
Then at the front of the code put [ youtube]
Then at the end put [/ youtube].
But with out the spaces^
