- 17 Jan 2006
Hi all, Not sure if this is the right section or not.
I'm currently experiencing a problem with my computer which is causing games to hang then crash.
Initially I noticed it when trying to play HL2 Episode 1. I figured after much reading that it was most likely the very common source sound looping crash bug. and have been trying to remedy that, however thinking back I have a feeling it might be something else.
My system spec,
P4 2.8Ghz
1GB RAM (2 512 Sticks, unmatched)
Geforce 7800GS OC (AGP)
I had forgotten that when trying to run Far Cry I had troubles. When I first installed it, I only had 512MB RAM, and the game would lag pretty badly. SO I purchased another stick of 512 (I think it Was Crucial). After this, I still had problems and, it kept crashing, so I gave up with it in the end.
I had also forgotten that fairly recently, I had purchased Max Payne cheap, and played through that. I also experienced similar problems with it locking up and the sound looping.
Yesterday, while trying to get Episode 1 working, I finally managed to get to an error dialogue that popped up saying: hl2.exe the instruction at 0x241f94f7 referenced memory oxoe51f41c the memory could not be read.
Would this indicated a memory related problem, such as one of my sticks not working, or the unmatche sticks not liking each other or something similar??? If so, what steps can I take to diagnose what the problem is?
Any help would be very much appreciated!!! As if this is a problem with my comp rather than with the games as I initially thought, I'd love to be able to get it sorted as I have loads of games I could then play through.
Valve
My system spec,
P4 2.8Ghz
Valve
