Specs:
CPU:
INTEL i7-5930k 4.20Ghz(OC)
CPU Cooling:
AOI Liquid Cooled, with the case fans ofc
GPU:
2x NVIDIA GeForce GTX 980Ti - SLI
RAM:
32GB Corsair Vengeance DDR4 2666Mhz (4x8Gb)
Motherboard:
ASUS Rampage V Extreme Intel X99
Primary Drive:
SSD Samsung SM951 512GB M.2 PCI-e
Secondary Drive:
SSD Samsung 1.0TB 850 EVO x2
Sound Card:
7.1 High Definition Audio Onboard
Power Supply:
Super Flower 1000W
Case:
Corsair Graphite 760T
OS:
MS Win 10 Pro 64 Bit
Display:
Acer Predator XB270HU 2560x1440 G-Sync 144Hz
So its only happened recently in the past month i would guess that my games start to briefly freeze up for about 15 seconds, now i looked a MSI Afterburner and at the time of the freeze the Power Usage dropped from like 85% to 30% then back to 85% when the freezing stops, my temps on my GPU are 80 - 83 degrees Celsius so thats normal, second GPU is fine no idea what is causing it, only settings ive changed is prefer maximum performance in the 3d settings, enabled sli and g-sync on windowed and fullscreen.
As for the Overclocking failed, that would be the CPU as its the only thing overclocked in my machine, to be honest ive only had this show once at start up before today which it happened 3 times in a row.
Any Help would be greatly appreciated.
CPU:
CPU Cooling:
GPU:
RAM:
Motherboard:
Primary Drive:
Secondary Drive:
Sound Card:
Power Supply:
Super Flower 1000W
Case:
OS:
Display:
