Games problem
30 Jun 2012
Village of Hessle, Hull
Hey guys, When playing games on my 2nd build I get some kind of glitch. A large black line appears for a split second at the bottom of my screen then my fps seems to get cut in half, after around 5-10 seconds later the black line reappears and my fps is restored. This happens every minute or so and is very annoying when playing oblivion/bf2. When running MSI Afterburner I see that when the line appears and my fps is cut my gpu usage spikes from around %50 usage to '100-120%' for a split second according to afterburner.
Spec:
2 Monitors
GTX 275 not OC
AMD Phenom II x4 940 3.0ghz
mobo: MSI P45
Kingston 1333 RAM
Ok same thing happens except the black line occurs on the same monitor and not the one I was playing the game on. Monitors are both Viewsonics VA2213w and VP171b-2
Solved: Googled Oblivion Stutter Remover that fixed my oblivion problem and I have a hunch the bf2 problem is caused from an ini file i tweaked earlier today. Thanks for the help anyway.
