Hi all and thank you for anyone reading this and can provide advice.
A few days ago my games which I launch through steam are suddenly running at an increased speed. For example when playing Metal Gear Solid V: Ground Zeros and TPP, character runs at increased speed, reloads quicker, rain falls to ground quicker, enemies react quicker etc. It's like the entire application is on 2x fast forward. I've tried running other games and also notice the same issue.
A few things I've tried which unfortunately have not worked:
- V-sync on through Nvidia control panel
- Triple buffering on through Nvidia control panel
- Rolling back NVidia drivers
- Completely uninstalling drivers and reinstalling latest version
- Setting CPU back to stock (it was overclocked when shipped and stable for 8 years) i.e. loading fail safe defaults in BIOS
- Fresh install of Windows 10
- Reinstall of games
- Setting affinity to CPU 1 / 0 through task manager
- Moving Graphics Card to different PCI slot
Just over two weeks ago I cloned over HDD to SSD and all was working fine. I also cleaned out inside of PC (removed dust) and for two days thereafter was also working fine. 3 days following that the issue came about. I'm not sure if I caused any problems when doing clone / clean, I did however as mentioned above do a clean install of Windows on the SSD. Obviously moving from HDD to SSD has quicken up loading etc. but would not expect it to make games once alrady loaded to run at 2x speeds.
I originally purchase the packaged system from Overclockers in Aug-2010 - "Ultima Viper" Intel Core i7 930 2.80GHz @ 4.00GHz DDR3 System.
Upgrades since then:
Jan-2015: Swapped Sapphire Graphics Card HD 5870 to Msi GEForce GTX 970
Sep-2015: Changed RAM to Corsair CMZ12GX3M3A1600C9 12GB (3 x 4GB) DDR3 Vengeance Memory
Jan-2018: Changed HD from Seagate Barracuda 7200.12 (1 TB) to Samsung 850 Evo (500 GB)
So current System spec's:
CPU: I7-930 (Bloomfield)
MB: Gigabyte X58A-UD3R
BIOS: Aware Software International, Inc. Version F5, Date 03/11/2010
RAM: Corsair CMZ12GX3M3A1600C9 12GB (3 x 4GB) DDR3 Vengeance Memory
Graphics Card: Msi GEForce GTX 970
I have reached out to a local repairer to see if they might be able to diagnose as unfortunately I don't have a second system to check the card with or a second card to check in this system.
Happy to provider further details if needed.
Thanks.
Thanks.
