Gaming & 4K video PC: Need help deciding!
27 Jun 2018
Hello everyone.
For the past four-five years I have been wanting to build a new computer, but each time I sit down and read up on parts I always find that in x-months something new will arrive.
The use:
The use will be gaming primarily, but I will also use the PC for photo & video editing.
Scrubbing through 4K timelapse from edited RAW files is something the PC needs to tackle with ease.
My thoughts and concerns:
I have tried to read up on everything, but it seems like the forums of the internet is divided on a lot of topics. Please note that I have some fundamental knowledge about computer parts, but I haven't dived into all the new things. That's why I have to ask someone else for feedback.
One of my biggest concerns is the choice between the 2066 and 1151 factors. Or maybe even AMD?! AMD has most cores and threads, but it seems like Threadripper isn't showing to be the better choice in video editing? Please correct me if I misunderstand something here. Some say that Adobe programs "fit" intel better because of the coding.
There is just something telling me that getting the latest Intel generation is the best. 2066 has been around for a while, right? Although 2066 seems to be the better choice when it comes to a video editing rig...
From what I have read, video editing depends a lot on high CPU clockspeed, many cores and a lot of CUDA cores.
The 1151 CPU's have more MHZ compared to 2066, which seems to be good for Photoshop and most of the adobe collection (premiere, after effects) - according to a lot of benchmarks I've seen. (https://www.pugetsystems.com/labs/a...ormance-Core-i7-8700K-i5-8600K-i3-8350K-1047/). My biggest concern and what's keeping me on the fence, is that many of the tests are several months old, or from 2017.
According to a lot of comments on the internet say that a big un-adressed variable in the adobe benchmark testing is that it is not a "real world" test, since all the cores are not fully utilized in the test. Normally I would use the computer while rendering, which I guess is where more cores comes in handy.
The i7 8700K seems to be close to some of the top CPU's, but is relatively cheap. It only has 6 cores and 12 threads. But, will I benefit from having a CPU with more cores, although tests show that having "to many" cores will actually give a decrease in benchmarks.
The 2066 factor supports 128GB memory, although I don't think I will ever need or afford more than 64GB. If I was professional I could probably defend the need of 128GB.
2066 also has more PCIe lanes, and supports CPU's with more cores and threads.
Will PCIe lanes be a bottleneck if I choose 1151?
After finding this forum, I read a post here: https://forums.overclockers.co.uk/threads/4k-video-editing-spec.18810927/
Saying "as mentioned, z370 was a rushed job, you'll find H370 boards will have better VRM and more chipset features then z370 and will cost a bit more then budget z370 - though not sure how long z390 will take to enter the party"
According to http://www.hexus.net/tech/news/mainboard/119525-intel-z390-chipset-expected-z370-rebrand/ it will arrive in the autumn 2018. It will support 8 core coffee lake.
As I mentioned in the beginning of the post: I've been on the fence for to many years now. If I wait until spring, there will probably be something else new around the corner.
One alternative could be to buy a cheap motherboard and CPU, and upgrade in the autumn? What would you do?
Having problems deciding between the sockets, you can be certain that I have the same problems with choosing other parts.
Before writing this post I had landed on these specs:
Case: Cooler Master HAF X Big Tower. I like space when I work.
PSU: Corsair TX750M, 750W (I may need to get something better, as reviews and comments are not the best. But goddamnit PSU has gotten expensive!)
Motherboard: ASUS ROG Maximus X Hero, Socket-1151. It was either this or Gigabyte Z370 AORUS Gaming 7. The latter having three M.2 ports and two LAN ports is very positive. But reviews seems to recommend the ASUS ROG Maximus X hero. I also wish to try Overclocking, and it seems that ASUS is better?
CPU: Intel Core i7-8700K. As said earlier. Benchmarks seems to praise this CPU compared to the much more expensive intel cpus.
GPU: ASUS GeForce GTX 1070 Ti ROG Strix. According to tests, there is only a very small gain in percentage between 1070 and 1080ti.
https://www.pugetsystems.com/labs/articles/Photoshop-CC-2018-NVIDIA-GeForce-GPU-Performance-1139/
MEMORY: G.Skill Trident Z DDR4 RGB 32GB 3200Mhz. (2x16gb). I am very green on memory, but I've heard that G.skill is very good.
HARD DRIVES: Samsung 970 EVO 500GB PCIe M.2 SSD. I will get two of these. One for OS and programs, and one for media. Ideally I should also have a third for adobe cache and output files.
CPU cooling: Noctua NH-D15. I haven't decided between air and water. Some say 8700k needs water cooling. Others say "if you water cool you need to delid". I don't even know what that is, but it sounds like sanding the metal on the cpu. I'm not keen on doing that....
Budget:
I live in Norway, so it's not easy to give a comparable budget because of norway's expensive taxes ++.
The parts I have listed is 25300 Norwegian Krone. Which is 2350 GBP. I may be able to stretch everything to 30000 NOK - 2800 GBP.
I hope to get some good feedback on my thoughts and concerns.
Thanks for reading.
@Jan Arvid Grimsrud
Welcome, seems you've done your homework , those articles from Pug is great!
thought about using DaVinci Resolve for 4k editing as well ?
also, worth Serious thought into Ryzen 2700X - these tests were on the last gen which is slightly slower as well as slower ram for ryzen. in theory the 1800X should have beaten the 8700k in Prem but not Photoshop.
Problem with X470 is lack of PCIe lanes, which can be overcome by using the 2nd GPU slot which brings our Prim GPU slot down to X8 speed.. and to be far you wont notice any bottleneck - only Volta/Titan V would highlight this or Thread Ripper 12 core X399 system ... many NVME drives as you like, though to be fair you wouldn't need that much
another question is, do you want to overclock? i7 8700 non K and H370 Board is quick enough as all cores boost to 4.3Ghz , 8700k is also 4.3ghz but believe M.C.E can pull this up to 4.7ghz but gets HOT! and manually overclocking is better
you'll also notice, savings can be made by having standard SSD for OS and Games/apps - pool your cash into larger NVMe drive to handle Adobe program- work and cashe or split it between like you've mentioned . scratch disk could be vastly smaller
also tell people that once their work has been completed to move off SSD- what ever type it is to HDD for storage or external
Yes you have done your homework,
Anyways i put my 2 pence worth regarding which power supply to get.
I have read years back that buying a cheap power supply is a no no because it could fail and could effect your pc components.
Either way i could get slapped about cheap power supply's from whoever is an expert on power supply's you see, because they could be decent enough, but as for me i'd stick with tier 1 power supply's to be on the safe side.
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/
I would recommend a tier 1 power supply out of that list, some cheaper than others like superflower power supply when compared to seasonic power supplys.
If you didn't know go with a power supply labelled as continuous power and not peak power.
Tier 1 - Best
  • Aerocool - Project 7
  • Antec - High Current Pro, High Current Platinum
  • be Quiet! - Dark Power Pro P10, Dark Power Pro 11, Straight Power 11
  • Bitfenix - Whisper
  • Cooler Master - V-series (modular, not to be confused with the VSM), MasterWatt Maker
  • Corsair - AX, AXi, HXi, RMi, RMx, SF, grey-label HX (2017), 2017 TXM greater than 650W
  • Enermax - Platimax, Platimax Digifanless
  • EVGA - G2, P2, PS, T2, 1000G1, 850W and above GS, G3 is on hiatus right now as current reviews are indicative of poor implementation of protections
  • FSP - Aurum PT
  • LEPA - G1600
  • NZXT Hale90V2
  • Riotoro - Enigma
  • Seasonic - X, Platinum, Snow Silent, all Fanless units, Prime, Focus Plus Gold/Platinum
  • Sentey - Platinum Power, Golden Steel Power
  • Silverstone - Nightjar
  • Super Flower - Leadex Gold/Platinum/Titanium, Leadex II
  • Thermaltake - 1250D-T RGB, Toughpower Grand/RGB 1200W
  • XFX - Pro Gold, Pro Black, XTS
@Jan Arvid Grimsrud
Thanks for the quick reply.
I'm trying very hard to include AMD into the choices, but I always end back with Intel. It may very well be because I'm ignorant and uneducated towards AMD.
I would like to play around with overclocking, but haven't really tried this since the time we had to play around with jumpers on the motherboard. It never ended well.
What does M.C.E mean?
I will look into getting a standard SSD for OS + apps + games. I intended to buy a extra SSD later and reconfigure everything. Perhaps I will just go all in at the start. Maybe 500gb won't be enough for the OS ++ disk.
Smaller scratch disk sounds smart. I also intend to use a 7200 rpm disk for media storage when I don't work with the files. I have a old media server that serves that purpose now, and a NAS for backup.
I'm still on the fence when it comes to 1151 vs 2066. I'm afraid to miss a lot of the "pro" features in 2066: more cores, more pcie lanes, more ram possibilities.
Also, a big question is which socket is most future proof?
As of now, it stands between 1151, 2066; or buying a cheap motherboard of either 1151 or 2066, and upgrading when intel pushes out something new (8 core coffee lake?)
Tier 1 - Best
  • FSP - Aurum PT
  • LEPA - G1600
  • NZXT Hale90V2
  • Riotoro - Enigma
Thank you also, for the quick reply.
I agree with you. I think choosing a good, more expensive PSU is clever in the long run. I just got a chock when most "good" PSU were in the 120+ GBP price range. And I have to try "cheaping down" somewhere :D
TR2 will be a bit of a wait for you :(
Thread ripper worth it over x299 but not worth getting a first Gen x399 :(
You make an excellent point that I haven't thought about. First gen motherboards aren't the most stabile thing are they...
I guess new TR will come in in the autumn 2018?
That leaves me with 1511 vs 2066. Will have to look at 2066 CPU and motherboard reviews then. I've concentrated on the 8700k.
Well as for me when the 2700 x is used to it's fullest with all cores and threads used, it is faster when compered to 8700k
So either a 2700x or 8700k, in the end i went with 2700x because it is faster and better value for performance, but the intel has a higher ipc.
Yes faster than 8700k when a program uses all of the cores and threads the 2700 x has to offer.
For instance this
The ryzen 1600 trashes the i5 and back then you either decide between 1600/x or 7600/k.
Now it is 2700/x vs 8700/k.
You should wait for TR2, if your able to use that processor to its fullest like with the picture and ryzen 1600 then it is a no brainier.
Just food for thought and what you ultimately will settle with.
Gaming at 4k then yeah, it will be using the gpu more than the cpu, so if you had a weaker cpu when compared to a stronger faster cpu you will get the same frame rate/ frames per second for example because it is using the graphics card much more than the processor.
My two pence again, anyways you have done your homework so i rest my case.
No, I haven't done my homework when it comes to AMD, I feel.
I've only had a quick look at some Adobe benchmarks, where the Ryzen 1700x and 1800x are compared to 8700k and Intel's highest level CPU's.
But the test is old, and I haven't found any adobe benchmark tests regarding AMD Threadripper.
As I said in my first post: I don't think the benchmark tests give justice to the CPU's with many cores and threads, since the test ONLY measures one thing at a time. Actually, some tests and comments conclude that having MORE threads and cores actually give a poorer outcome. So, something seems off. In a real world scenario, I think we all would multitask. Like, when rendering a video I may edit some photos.
Edit: Here is a review comparing TR and intel.
https://www.pugetsystems.com/labs/a...-Performance-Core-i9-7940X-7960X-7980XE-1034/
Seems like TR 1950x is a little slower than 7900x, but 7900x is a little more expensive.
https://www.pugetsystems.com/pic_disp.php?id=43384&width=652
They are very good with benchmarks but you have to pay close attention , they used the highest possible ram for intel b360 board being 2666hz .
Ryzen would gain a a good 3-5% jump with 3200hz ram and bring it closer to intel, add in the faster second gen 2*** series and it should do very well
I've done some more reading. I think this soon deserves a master degree!
I found a video on youtube. https://www.youtube.com/watch?v=ofdh-THQFpE
Interesting stuff, which highly speaks of using the 8th generation intel CPU in Adobe, because of it's Intel GPU. The Intel X series does not have this iGPU. So this, and the high price and that the CPU's have been around for a year atleast (?), really leaves Intel X gen out.
Although, **** gets nasty in the comment section, where people say Davinci Resolve is said to be a much better/easier/cheaper program compared to Adobe.
I have never thought of using Davinci because it seemed to be what "pro's" use. Like cinema motion picture - pro's. And for color grading.
Now I see that Davinci is not very costly (compared to Adobe cloud monthly payments, which is rediciously high), so I would be willing to try it out.
This means I really should include AMD in my thoughts again.
It's great, friend uses it and made one of the Smaller Super markets here in the UK TV advert with if .
Does require some heft gear though !!!!!
Though he did it on a very old PC and will set him up with something that can handle it, specially when he bought a £1300 10 bit monitor and can't actually use it haha
https://www.pugetsystems.com/labs/a...U-Performance-Skylake-X-vs-Threadripper-1063/
https://www.pugetsystems.com/labs/a...-14-GPU-Performance-NVIDIA-Titan-V-12GB-1108/
Considering TR 16 core is now £620 in UK..damn..
Worth getting a piece of work, trying both of it in current programs and see how you get on :)
