" Gaming boost " on b450
17 Feb 2009
I see in the bios there's an option to enable gaming boost
I assume this is for people like me who have no knowledge of overclocking , except ram ?
Is it safe and would It increase my fps in cyberpunk 2077?
I have a 750w corsair psu, noctus nh-u12s fan and ryzen 5 3600
Thanks
Ganing boost is an auto ovetckock feature for the cpu, keep an eye on temps. If your using a stock cooler i wouldnt do it.
It should have a small increse in fps but you can test before and after.
Not using stock cooler it's a noctua nh-u12s.
I may give it a go and if temps too high then turn it off
Wont cause any damage will it ?
Fair enough. I may try to do it manually .
Increase the MHZ and voltage slowly ?
What should I be aiming for on a ryzen 5 3600 ?
How does overclock affect the boost ? One core usually gets to 4.2ghz and the others 3.9ghz...
Also what's a safe voltage ?
Think I'll leave it. Likely the bottleneck is due to my rx580 and overclocking a CPU which already overclocks itself is risky
