no build pics
what did you end up buying then?
I have got a few pics of the build, not loads though.
The motherboard was the first thing to arrive:
Then everything else turned up about 30mins later:
Motherboard securely in place:
The brains behind the outfit:
The CPU and PSU installed:
This is just before I powered it on for the first time:
A flicker of life:
Windows, everything working ok. Just need to install the graphics card now:
After everything is installed, just need to do some cable tidying:
Just about to start copying over my files and install those essential programs:
So all in all i'm well chuffed. My previous build had cathodes, sunbeams etc etc but I'm not sure if I want to go down that road again, if not I'll probably get another case.
