Gaming Build £700-£800
21 Feb 2006
Home
Hey guys. My friend is looking to get back into some PC gaming and needs a complete base unit build.
I’m assuming Ryzen is the way to go, but I’m not up to par with the knowledge.
Needed;
CPU/Cooler
Mobo
Ram
Gfx
PSU
SSD
Case
He will be gaming at 1080p/144hz.
Many thanks.
Needed;
CPU/Cooler
Mobo
Ram
Gfx
PSU
SSD
Case
Many thanks.
Intel has edge at 1080p gaming. But normally that's with expensive high end GPUs which the budget wouldn't cover so AMD would be best train of thought .
Wait till b550 is released for pricing
I doubt any will be that cheap unless they are completely stripped of features besides what use is pcie gen 4 for a budget gaming PC?.
Should be a few from Gigabyte , MSI and ASRock that are under $90 at least stateside . Again that matx Toma shouldn't be anywhere near £100 mark , even if sterling increased. Actually dropped a little from £80 odd when AMD said only x570/B550 were only ones to run Zen3 .
And you say budget PC £700... PCIe 4.0... what is Xbox and PS5.. actually running m.2 PCIe 4.0 at speeds they should be . Development from Xbox already finding was into DX12 which should help least PCIe 3.0 get a boost over sata 3 SSDs (fingers crossed )
Hi, thanks for the suggestions. Why mATX builds?
Will that not prevenbt future upgrades etc?
Tbh MATX has most people covered these days. Not worth cost or performance to xfire/sli. Have 4 dimm slots, min 2 x M.2 slots. Plenty of USB and SATA ports. Second PCIE slot for sound card or similar if wish, decent VRMs etc.
With that the boards are cheaper than ATX and allow more room in larger case for water-cooling setup or smaller overall build depending on preference.
