gaming build £700 max excluding del
10 Feb 2013
Hi guys ive just recently built a gaming pc with componants bought from here.
i5 4670k
270x
8gb ram
gigabyte 87x-sli
1tb
550w superflower gold
ive decided to give that to my lad and build another for myself.
I have a limit of £700 excluding delivery costs. I would like to get a r9 280/x and a 4670k into the build and a motherboard chipset like z85 since ill be swapping mine for the z87-sli as my sons wont be overclocked at all.
no os needed or m/k monitor.
use ur magic guys :)
id really not recommend a z85 board under any gaming circumstance! the £20 youd save by going B85 really isn't worth it, especially considering the extra hassle of rebuilding the other PC with it
edit: spec inc - any requests on color scheme or styling?
over budget, and i chose some of the most budget parts available! i think you'll struggle getting the price to £700 max with your component choices, id also suggest waiting until it's in stock and choosing RJC's psu suggestion, having said that, the one i chose shouldn't give you any problems! good luck with your build, let us know what you decide
YOUR BASKET
1 x Gigabyte Radeon R9 280X Rev1.0 WindForce 3X 3072MB GDDR5 PCI-Express Graphics Card £254.99
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - OEM £169.99
1 x MSI Z87-G43 Intel Z87 (Socket 1150) DDR3 ATX Motherboard £86.99
1 x Corsair Builder Series CX 600w Modular '80 Plus Bronze' Power Supply (CP-9020060-UK) £62.99
1 x TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38GM1600HC11DC01) £59.99
1 x BitFenix Shinobi USB3.0 Gaming Windowed Case - Black £59.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £47.99
1 x NZXT Respire T20 CPU Cooler £26.99
1 x OcUK 20x DVD±RW SATA ReWriter (Black) - OEM £16.99
Total : £801.00 (includes shipping : £11.75).
YOUR BASKET
That mobo comes with a free fairly decent cooler;
YOUR BASKET
1 x Sapphire Radeon R9 280X Vapor-X OC 3072MB GDDR5 PCI-Express Card £245.99
1 x MSI Z87-G43 Intel Z87 (Socket 1150) DDR3 ATX Motherboard - FREE Alpenfohn Civetta Cooler!! £86.99
1 x Corsair Builder Series CX 600W V2 '80 Plus Bronze' Power Supply (CP-9020048-UK) £59.99
1 x TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLAD38G2400HC11CDC01) £55.99
1 x BitFenix Comrade Midi-Tower - Black £29.99
Total : £727.42 (includes shipping : £11.25).
I was just looking at that, the case can take coolers upto 160mm in height, I think some one else had issues.
The product description is a bit misleading, as I don`t think they have accounted for the height of the fan when fitted.
true, but i didn't want to suggest something which could leave him with a (potentially) unsatisfactory overclock and it be my fault! :p OP i think this spec is the closest you'll get to your budget ^, the Z87 board potentially works out cheaper than a B85 as it comes with a cooler which should let you do a moderate overclock
Well that cooler can't be that bad xD It's £27 over, but if you want Intel and a 280x then there it is. Drop the DVD writer and you might be a bit closer (install windows of a USB or perhaps borrow another drive for the installation? :) )
