- 10 Jul 2012
I have build a gaming PC for the first time and don't know if I have made any mistakes. It starts up without any problems, and fans are spinning, does this mean I have connected everything?
Will give it a check, any other advice?Well if everything's booting ok and is stable, the temperatures are ok, there aren't any funny sounds and it runs like a computer should then I would say it's ok. Generally you only realise it's been put together wrong only when something stops working, but if everything's running it's probably ok.
I watched the two videos before I build the gaming PC, and I build it similar to the one shown on the video, but only started the PC just to make sure it worked and turn it offdid you build your rig like this?
if you did, it should be fine (barring any doa parts)
Which benchmarks should I test with which software to use? I'll check if SATA is in AHCI mode in BIOS,yeah. You can install the OS and run some benchmarks to make sure everything's up to speed.
Make sure you have SATA in AHCI mode in the bios, and that's a about it.
Since the PSU that I have has a 135mm fan, I've faced the fan to the bottom of the case, I've provided a image of it with a red arrow,
I'm using OCZ ZS Series 550W PSU which provided cables to power up components. In one SATA cable, it has 3 ports head, does it matter which one I plug in?
not sure how the HDD button on the front works
Will give the softwares a try for benchmarkGraphics : Unigine, 3DMark 11, GPU-Z, MSI AFterBurner.
System : OCCT / Prime95, HWMonitor, CPU-Z, CineBench 11.5.
Memory : memtest86.
Drives : CrystalDiskMark, ATTO, BootRacer.
My computer desk is similar to this one, the PC is placed in the same place as in the picture but the place is wider,yes... On the Z9, fan up. IF your computer sits on the desk, then down is fine, but on the floor, up.
I faced my PSU up, thanks for your advicefan up
If I'm not wrong, I've 3 intake fans near the motherboard with the PSU fan facing up, is this a good airflow?
http://i.imgur.com/rnTWe.jpg
The 3 fans near the motherboard are set as exhaustThe two top fans should be blowing straight up and out of the case?
Thanks for the correction, feeling good that I have setup the fans correctly for a good airflowYour fans around the heatsink are actually set as exhaust not intake. I have mine the same![]()
Will unscrew the motherboard and tuck the fan cables under it for a neat finishI actually tuck the ceiling fan cables out the back through the holes in the mobo tray. Then connect these top two fans to the fan controller. The dial on the front controls the speed of these fans and dims the light when set to low.
Removing all the optical bays cover in the front panel? Will it not cause a lot of dust coming into the case?I remove the metal blanking plates from all the optical bays behind the front panel too. The ceiling and heatsink fans will draw the air in from here, so it's worth popping them out to improve airflow. There are dustfilters in the front panel![]()
I took the fan off the side panel and placed it at the top of the case as exhaust, my expansion slots 2-3 is used as graphics card and accidently ripped out the first expansion slot but will fit a sound card in there to replace itIt sounds like a faff because it is. I can honestly say though, that it does help with noise (im hoping you took the fan off the side panel). Temps were definately better after the mod, noticed 2 degrees knocked off my GPU too at idle......good considering the case is pretty much full with expansion cards![]()
