Hi, this is my first time builing a computer so i'm a bit paranoid that the hardware isn't compatable or won't do what I want it to do. I'm building a mid range gaming PC, budget is about £1000 (Including peripherals) and these are the parts I've chosen:
Case: NZXT Phantom Full Tower (Comes with 4 fans, is this enough?) - £99.99
PSU: Be Quiet Pure Power 730W Modular - £67.71
Processor: Intel core i5 2500K 3.3Ghz - £174.79
RAM:Corsair 8GB DDR3 1333Mhz 2x4GB stick - £34 (£35 for 1x8GB stick)
Graphics Card: PowerColor HD 7850 2GB GDDR5 - £191.40
HDD: Seagate 2TB Barracuda - £79.99
Optical Drive: Samsung SH-222BB SATA DVD Write - £12.99
Motherboard: Gigabyte GA-z68X-UD3-B3 Z68 Socket 1155 - £70.20
+ £80 for windows 7 home premium
Total - £812.21
With peripherals it comes to £966.71.
My main concerns are the case, motherboard and PSU. Will it all fit in the case and will it have enough power? Will the parts all be able to connect to the motherboard?
Also I need advice on RAM, should I get 2 4GB sticks or 1 8GB stick? They're the same price so I thought having an 8GB one would future-proof it a little, but will 2 4GB sticks be faster with Dual channel?
Finally, what would you recommend in terms of wireless network adapters? I've always used laptops with built-in wireless so I don't have much experience in this.
Thanks!
Total - £812.21
Thanks!
