Permabanned
- 19 Oct 2011
Hello everyone, first time using the boards, I usually just read them, but this time I need some help and advice on a gaming PC I'm going to build, this isn't going to be one of the over the top builds, just enough to let me run current and coming out games at max settings @ 1680x1050.
I already have parts in mind and I would like to get your opinion's
I have no need for hard drive/OS/dvd drive, already have them in the computer I'm using and they are fairly recent so can be recycled.
Proccessor: Intel Core i5 2500K
Graphics card: 2x Asus GTX 560Ti DirectCU II 1GB
I will not be buying another 570, so would 2 560ti's be better value/performance wise (works out to around £40 difference)
Case: Coolermaster Elite 430 (Not sure on this, pretty sure i would need a much better case with proper cooling if I'm running 2 cards)
Motherboard: MSI P67A-GD53 (B3)
Ram: Corsair 8GB 1600MHz
PSU: Some 700-750w haven't decided (£65 max though)
All together comes to around £710 with some discounts thrown in!
I know i need some sort of cooling or something (most likely just a much better case ~£80 with ventilation, options?)
And CPU cooling....
Open to suggestions
And CPU cooling....
Open to suggestions
