Gaming Build
18 Oct 2002
Swansea
Hi all , i was given a gaming system off a friend about 2 maybe 3 years ago from here , specs are
Windows 7 64bit H.P.
Antec 900 case (blue led's)
Gigabyte GA 965P- DS3 motherboard
Corsair CMX2 DDR2 1024 x 4 sticks
Corsair TX650w power supply
Geforce GTX275 card
Intel Dual core 6600 cpu
Sata DVD RW drives
Sata 300gb and 400gb HDD
its lasted me long and served me well , i play WoW and BF3 plus some other games but i think its time to upgrade. Please Please help me out ive got a budget of £800, but i can strech a little bit more, ive got a 24" monitor which i run at 1920x 1200 and it seems ok plus ive got all the other things keyboard etc... can i salvage anything from the kit ive got already ? i can build it if needed but would love it all done for me. Any suggestions would be awesome .
thanks in advance and sorry for the long post
You can salvage,
Case
PSU
SATA DVD drive
SATA HDD drives
So all you need to do is chuck a modern Z68 board, i5 2500K and DDR3 RAM and a SSD would be nice to run the OS from and what ever games you can fit on it,
YOUR BASKET
1 x HIS HD 7950 3072MB GDDR5 PCI-Express Graphics Card £334.99
1 x Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £179.99
1 x Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT128M4SSD2) £139.99
1 x Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard REV 1 £78.98
1 x Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (BLS2CP4G3D1609DS1S00CEU) £37.99
1 x Xigmatek Gaia CPU Cooler (Socket LGA775/1155/1156/1366/2011/AM2/AM3/FM1) £19.99
Total : £803.94 (includes shipping : £10.00).
i was thinking of adding an SSD maybe a 128gb , i mostly game on it , i know WoW takes up some room. would the power supply be ok for the newer better graphix cards out there ?
For the spec above your PSU is fine:)
The motherboard is ok for a single GFX card so dont expect SLI/Crossfire (your PSU isnt enough for a pair of 7950 cards anyways, but one is ok)
This is that 7950 card - http://www.guru3d.com/article/his-radeon-hd-7950-review/
thanks for the reply , will they still be quiet , i cant hear the case fans or the cpu cooler fan at the moment , would i need any more than 8gb ram ? i dont really like overclocking a PC so would they come as standard ?
The RAM question has been addressed here - http://forums.overclockers.co.uk/showthread.php?t=18377873 - to save you the time of reading it, 8GB is brilliant (with a 64bit OS)
The aftermarket cooler will be quiet, the card in that review is described as,
For the card in a fully stressed status (in-game) 41 DBA, now that is slightly audible, very normal. It means you can hear airflow, but that's it.
In the review link I gave above.
Overclocking these unlocked "K" CPU's is as easy as changing the CPU multiplier from 33X (33X100Mhz=3.3GHz) to say 40X (40X100Mhz) = 4Ghz:)
Theres a beginners guide here for that same motherboard - http://forums.overclockers.co.uk/showthread.php?t=18375640
gaming
Sorry guys things have changed a bit now , i want to have a new system minus mouse keyboard monitor and os , so i need case , board , ram , cooler , Cpu , graphix card , psu and DVD writer , it really needs to be coo las its in a kind of warm room and i really would like it to be sas quiet as poss , budget is now between £800 - £1000 , would it be poss to have a 256gb ssd and as future proof as poss , many thanks in advance.
ps its mostly used for gaming WoW and BF3 , its running on a 24" monitor
would thte standard case fans that come with it be sufficient and quiet or would i need to upgrade them ?
would all the parts come with all the things i need to build it ?
thanks
Seeing as te fractal is out of stock can anyone recommend me an alternative to it the system needs to be cool and quite
Thanks
Thanks
Corsair 550d silencio is a very very quiet case but IMO it lacks in cooling when using all sound dampening. Ask as a seperate thread in case central. I'd upgrade to ivy bridge and a z77 mobo
