Gaming build
Permabanned
22 Dec 2010
West Lothian
What do you guys think to this build?
Budget is 600-650
Will be mainly used for playing arma and squad.
£29.99 x 1 - Avexir Core Blue Series 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Memory Kit (AVD3U16001104
£49.99 x 1 - SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black
£43.29 x 1 - Crucial BX200 240GB SSD SATA 6Gbps Solid State Drive (CT240BX200SSD1)
£149.99 x 1 - Intel Core i5-4690K 3.50GHz (Devil's Canyon) Socket LGA1150 Processor - OEM
£51.66 x 1 - Gigabyte Z97P-D3 Intel Z97 (Socket 1150) DDR3 ATX Motherboard
£49.99 x 1 - NZXT Source 340 Midi-Tower Case- Black Window
£108.29 x 1 - Sapphire Radeon R7 Nitro 370 Dual-X 4096MB GDDR5 PCI-Express Graphics Card (11240-04-20G)Cooler Master Hyper 212 Evo CPU Cooler £29.99
Comes to about 600 pound or just under.
I already have peripherals, storage drive and monitor.
Will this run games half decent?
Cheers
If you max out your budget you could get a 380 which would give you a lot more grunt in gaming at 1080p/ high details.
If you want to stay at £600 then get the GTX 950 its faster than the 370
My basket at Overclockers UK:
Total: £659.04
(includes shipping: £13.20)
thanks for taking time to reply. do you think all the above gpu's will be enough to play games on high settings, my only worry is running out of vram.
At 1080p the 370 and 950 will struggle with high details but the 380 4gb or 960 4gb is the better option , the 380 edges it.
