Gaming Build
16 Jun 2014
I'm building a pc for a friend and I'm looking at this:
"Titan Karambit" AMD FX-4 4300 @ 4.0GHz Turbo Quad Core Gaming PC
Stock Code FS-094-OG
Built To Order
1
£491.95*
£491.95*
Your selected configuration: Edit Configuration
Build Time Standard Build Systems - Dispatched within 7 working days
Warranty OcUK Standard System Warranty - 3 Year (24 Month C&R + 12 Month Labour)
Security Software ESET Smart Security - Trial Key
Lighting Not wanted
Memory Kingston HyperX 8GB (2x4GB) PC3-14900C9 1866MHz Dual Channel Kit - Black/Red (HX318C9BRK2/8-OC)
CPU AMD Piledriver FX-6 Six Core 6350 Black Edition 3.90GHz (Socket AM3+) Processor - Retail
Case BitFenix Neos ATX Tower Black/Blue
Optical Drive Not wanted
Operating System Not wanted
Graphics Card KFA2 GeForce GTX 950 Black OC Sniper 2048MB GDDR5 PCI-Express Graphics Card
Primary Solid State Drive / Hard Drive Seagate SSHD 7200RPM 3.5" 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DX001) SSHD Hybrid Drive
Storage Mechanical Hard Drive Not wanted
WIFI Not wanted
Sound Card Not wanted
It's the right price, but I'm also thinking about re-using his old case and replacing the fan with the corsair h1100i watercooling sealed unit so I can push the overclock up a lot.
Am I wasting money by buying the same components, plus the watercooler, and building myself, or am I missing something even more important.
I'm also unsure the 450 superflower psu would be sufficent?
Thanks for your help1
I've asked him for a full spec but I think it is an old dell at least 5-8 years old. I'm waiting for his full reply though.. sorry..
Of course I will need to check that his case would take the radiator for a watercooling unit and isn't so messed up that generic ATX form parts can't fit in it.
core 2 duo e3850 3 ghz with 4gb ram, 500 gb hdd and a similarly naff graphics card. He wants a fresh case though, so I'm thinking that pointing him at the titanium karambit is his best bet?
Though I think I may have to upgrade the cpu cooler if we want to overclock it and maybe add some fans?
