"Gaming Bundles" question
28 Jul 2004
llanelli , south wales
decided to have a browes of the site abit ... as i was thinking of startign to put together a 2nd rig .
whats my best option for £400 ? and lookign to get 16gb of ram
http://www.overclockers.co.uk/showproduct.php?prodid=BU-001-GI&groupid=43&catid=2053&subcat=
Buy another lot of samsung green as it's among the best memory available at the mo.
my 2nd window was open on that one ...but according to notes below it , it wil affect OC which is why ther is a 2nd option of doing 2x 8gb sticks with corsair
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
**** easy to get ivy to 4.4Ghz, but yeah if you're not experienced or want to overclock just get the corsair memory. Can't get much better gaming system than this at the mo.
yeah but you loose teh tech support if you mess with teh ocuk settings when you get more ram
They save their OCs as a profile in the bios I think so, I'm not sure you can just create another one to test better overclocks with and if you can't do it or mess it up, just load up the saved OcUK profile and your settings will be restored. Don't quote me on that though, never bought an oc bundle.
