Gaming case needed (not sure what will fit)
9 Oct 2012
Hi guys
I am looking for a gaming case for about £20 with LED's if possible.
I am getting a gtx 660
ASRock H77M Motherboard
PowerStation Gaming 600W Silent ATX2 Modular Power Supply
These are the big things in the computer and i need a case that will fit it all.
Thanks
Jeremy
I cant really go any higher.
I am on a very tight budget.
It does not have to have any LED's i just need a case.
It doesnt even need to look very fancy.
You just better off asking if someone has a spare of case then. The cheapest Atx case on OCUK is over £20.
you cant get a gaming case for £20 though u can get basic cheap ones from the bay. I always bought cheap cases, but after advice from people on this forum i bought a more exspensive one, and i am glad i did, its worth the money, no point buying exspensive components and putting them in a cheap case.
I bought a good case from here last week Bitfenix Merc i think it was, £26 cant beat that and its a quality case, was shocked at the build quality :D
This one
http://www.overclockers.co.uk/showproduct.php?prodid=CA-010-BX&groupid=2362&catid=1850&subcat=
