Gaming Case recommendations
16 Jul 2010
I bought a new Corsair PSU, and realised with dismay that the only way I can get it into my Antec Sonata III case is to completely dismantle the entire PC.
So I'm thinking if I've got to take the whole thing to bits, I might as well get a new case to put it in, as the Sonata III doesn't have a lot of room to work with, plus I can use it for my next full build.
What I need is a case that's: a) Black to match my optical drives b) has plenty of room for a monster PSU, c) Is roomy inside so future upgrades will be easy, and d) is quiet - my Sonata III has rubber mounts for the hard drives for example. I'd also like if possible a slot suitable for a floppy drive because that's where my fan controller control panel sits.
Oh and e) it's got to be reasonable value.
Thanks
I've ordered one - the SATA hot-swap bay sold it for me. I've been meaning to get some sort of swappable drive backup system going for a while for offsite backup and that'll make it cheap and easy to do.
It's also a fairly unfussy design, which I much prefer.
Thanks again for your recommendations!
