Gaming channel advice/help
25 Jul 2013
Hey folks,
Looking for some advice, i want to start my own gaming channel as a hobby, been playing around with the ps4 streaming tool, but want to go a bit further and start editing videos too.
Can you recommend anything?
My pc requires upgrading but thats a seperate issue just now. Does anyone have any experience or run a channel can offer some words of wisdom.
At the moment its purely ps4 i want to do, and ill do pc further down the line.
Thanks
With regards to general advice I would say regular streams/content is the key.
Secondly , being good at the game helps.
First off, why do you want to? If its solely for income then I would say its saturated and we can do without another. If its for a genuine love of a particular subject, then go for it.
I enjoy it. Not for money. I work fulltime so money isnt the end goal. Just a bit of fun really. I game a lot. May aswell share it :))
You can use something like the Elgato HD60 to capture from your PS4's HDMI port or you can record using the built-in DVR at 720p on PS4 and 1080p on PS4 Pro but I think they're both only 30fps.
