just need the tower. got all the rest. how mush would it come to if i was looking a Intel i5 processor?
Sorry!Haha I got muddled up at first too, similar names and I know the guy you're on aboutOliver Renault, you are posting I5's now?![]()
thanks olivier i think i am going to go for the first one. will the rig be silent?
world this cooler reduce the noise? or suggest one that can.
http://www.overclockers.co.uk/showproduct.php?prodid=HS-020-AL
If you are going for the i5 in Olivier`s spec then yes, but will not fit in the Merc Alpha.
But if you are going with the i3, it is overkill, a £20ish cooler will suffice.
do you think you could suggest one becuase wouldn't know which one to pick?
The first on that was suggested![]()
Done you a revised spec as prices have changed since Olivier`s build. Forget about a cooler for the moment. That can be gotten later if you feel you need one, if temps are high or stock is to noisy.
YOUR BASKET
1 x MSI HD 7850 Twin Frozr III OC 2048MB GDDR5 PCI-Express Graphics Cards w/ FARCRY3 & Sleeping Dogs PC Games £149.99
1 x Intel Core i3-3220 3.30GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £89.99
1 x **B Grade** Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £60
1 x PC Power & Cooling Silencer Mk III Series 500W '80 Plus Bronze' Modular Power Supply - White £56.99
1 x Zalman Z9 Plus Tower Case with Fan Controller - Black £46.98
1 x Toshiba (7K1000.D) 500GB SATA 6GB/s 32MB Cache - OEM (DT01ACA050) £43.99
1 x Corsair Vengeance Blue Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CML8GX3M2A1600C9B) £37.99
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £14.99
Total : £515.92 (includes shipping : £12.50).
One last question will this run minecraft?
