Gaming CPU successor to 3700x
18 Apr 2004
Milton Keynes, UK
I've started gaming heavily mainly in shooters, FPS and soon racing games. Currently have 3700X and 3700ti card with 64GB DDR4 ram. I also edit videos too. Question is do I really need it and would it make that much of a difference? I've had my eye on the 5900x
I'd also favour best bang per buck however willing to spend more if it makes much difference. Also gaming on a 1440P monitor with 165Hz refresh.
At that resolution it will be the 3070 Ti being the bottleneck, however if you're editing videos often then the extra CPU grunt will definitely help a lot.
depend on the game. some games to get over 100fps @ 2K needs a lot of grunt so GPU bound. other games can shoot over 200fps @2k CPU bound.
the best is to see what game you are playing and see what the reviewers are getting at 2K res in FPS and compare with yours.
in all fairness if you are looking at over 150FPS you are more likely to be CPU bound than GPU bound so going to Zen3 chips will yield better experience but the question is really do you need those extra frames...
You won't gain much if anything in gaming when moving to zen 3 from zen 2 with a 3070ti@1440p however a 5900X would certainly speed up video editing. If gaming fps though is the priority then moving to a 3080 / 6800XT would be a better use of the cash rather than dropped the £500 on a CPU.
I've been getting average 160fps with my setup, usually set medium/high not ultra. Mainly been on Warzone, and Doom Eternal which again same average FPS. Not tried Apex yet and just started Age of Empires. Its crashing a fair bit so trying to see if its a driver issue or temp as its all stock coolers.
I struggled editing on my 970 card and it just about handled Canon C200 raw footage fine especially when I upgraded to the 3700X CPU setup. I'm keen to see and it should with the upgrade be able to handle C500 mkII RAW files at full 6K.
Not a pro gamer and the jump from 60 to 160Hz is more than enough for me.
I’d probably look at 5900X or maybe a 5950X. The 5800X would offer a decent upgrade but it’s still only a 8c16t CPU.
It's hard to describe any CPU as a gaming 'successor' to a 3700X, there's only been one generation ahead and I'd expect a successor to be more... meaningful. People are still upgrading to a 3700X. Like said above, it might help more with video editing, but that also depends on the software you're using.
Looks like you’ll gain about 20% in games maybe a little more with games that leverage 12 cores. With the current state of the graphics market that is actually good value.
Games won't be anywhere near +20% @1440P with a 3070ti and even 5% would be pushing it but that said productivity would get a decent boost with the 5900X.
Zen2 to Zen3 is about 20% improvement depending on how many cores can be leveraged and system config. You could see more than 20%.
5800x is your best bet. 5900x won't be any faster than that CPU for gaming at 1440p.
Whether the 5900x is worth it for you depends entirely on how much you do video editing and how much you value better performance in that.
I'm opting for best bang per buck performance. I'll look at costs... I went for the 3700x original because of that though sure some said the 3600 was better value.
It all depends on your needs and usage.
Best bang for buck for gaming is the 3600, it has been since its release. If you need 8 cores your best bang for buck is a cheap 3700x. If you want less bang-for-buck today, but you're looking towards the future or you potentially do video editing etc, then the 5800x or 5900x are better options.
I think I need to rephrase and add in the looking towards the future part. Not urgent at the moment so looking for a deal when it happens. Now to find a heatsink/fan that will fit the NZXT case.
I would wait, wont be that long before seemingly everyone has the 3+ and all the 3 owners will be green with envy
I think all the 3 owners will be happy for quite a while. I certainly won’t be upgrading to anything anytime soon.
There always will be something better on the horizon. Enjoy now and be happy
