Do you have a budget in mind?
couple of cheaper options below:
YOUR BASKET
1 x MSI Radeon R9 270X Gaming Edition OC 2048MB GDDR5 PCI-Express Graphics Card £155.99
1 x Gigabyte Radeon R9 270 OC 2048MB GDDR5 PCI-Express Graphics Card £129.95
Total : £295.54 (includes shipping : £8.00).
just wanting peoples opinions on a good graphics card upgrade, i currently have a geforce 210 but want to start to do bit of gaming counter strike, watchdogs,cod etc cheers
Yup, system spec would be useful, including resolution.
You can get a 750 for 100 odd, though a game like watchdogs is apparently quite demanding. The 750 should have no problem with cod and counter strike.
not sure of my resolution where do i find that?
I wouldn't recommend going any lower than an AMD R7 260X or an Nvidia GT 750 (with the 260X giving marginally better performance and having twice the vRAM).
If you go below those, you really start to get negative returns on your saving (i.e. an AMD R7 250X is 78% the cost of a 260X, but only gives 67% the performance).
I wouldn't recommend going for an Nvidia GTX 750 Ti (unless you have to for power reasons, since it has very low power consumption) just because of its price. You can get an AMD R9 270 for only £10 more than the cheapest GTX 750 Ti, and the R9 270 is a good 25% faster.
Also worth noting you get 2 free games from AMD (see link: http://sites.amd.com/us/promo/never-settle/Pages/nsreloadedforever.aspx) with the R7 260X or R9 270, whereas you only get some in-game currency for a couple of free-to-play games with the Nvidia cards in that price range. So if you were going to buy any of the games off AMD's list, it effectively makes the card cheaper.
Hope that helps![]()
What monitor do you have?
Alternatively, you can just right mouse click on your desktop and check out the resolution from there.
Yea 7850/265 minimum for gaming at 1080p. Anything lower/slower (which include 750Ti) should not be considered.270 2GB or 265x 2GB are the only choices I can recommend as a minimum for 1080p gaming.
