- 23 Oct 2002
- None of your business
Hey all,
Wanted to throw this one out in the open cause I think I'm on the right track but wanted a double check
Building this for a friend, and am considering one myself, as he's an avid gamer. Wants something with punch but also in a tiny package so ITX is the perfect way forward for him
Budget really isn't an issue at the moment but he's fixed on either i5 or preferably i7 even though it'll be a power killer!
The following spec is where I'm coming from:
Case: Cooler Master Elite 120 Advanced Mini-ITX Case
PSU: 675W PSU, ThermalTake TPX-675MPCUK (Already have this!)
Cooling Fan: Thermalright AXP-140 (Already have this!)
Motherboard: Gigabyte GA-Z77N-WIFI, Intel Z77, S 1155
CPU: Intel Core i5 3570K or i7 3770K, 1155, Ivy Bridge
Memory: Corsair Memory Desktop 8GB 2 x 4GB DDR3 1600 MHz
GFX: 2GB Gigabyte Radeon HD 7850 Overclocked
The PSU and cooler can be reused especially since the AXP-140 is low profile so would just need a suitable fan for him. The part I'm most concerned about is heat especially since the Elite doesn't get "fantastic" reviews for thermal management. I did consider the SG05's but then you'd have to downgrade the GFX card or start modifying the case which isn't something I want to do either.
Any input, changes, suggestions etc. definitely welcome cause I haven't dealt with putting something this small together before
Ta
Budget really isn't an issue at the moment but he's fixed on either i5 or preferably i7 even though it'll be a power killer!The following spec is where I'm coming from:
Ta
Considering its going to be a powerhouse of a system, I really don't want the CPU/GPU to start suffering heat exhaustion cause of inadequate cooling
