Gaming laptop - £1300 max, 970m, 17 inch - MSI vs Asus vs Gigabyte vs Fangbook??
26 Apr 2016
I did see the other, similar, thread, but I've got more specific questions....
I'm after a desktop-replacement type laptop that I can pack up easily and move with it, and have some gaming capabiliity, I know it won't compare to a normal desktop but at the moment I'm on a 2010 desktop with 2013 graphics card so due an upgrade anyway. Due to budget (ideally LESS than £1300) I'm looking at a 970m gfx card, on the assumption that 960m will be just too puny .....I am not a big graphics whore but I want a bit of future-proofing, i.e. I'm not so bothered about running 2016 games on full ultra settings, more about being able to run 2020 games at all. Apart from GFX I'm mostly bothered about keyboard and general system quality, not bothered about sound (will use headphones), battery life (will be plugged in), case design (whatever) etc. Avoiding Win10 like the plague would be appreciated too.
General questions:
1. Are Cyberpower Fangbooks worth considering at all?? They seem to be an MSI rip-off design-wise, but the make seems an unknown quantity to me even after reading up as much as possible??
2. Is the MSI GT series a sensible option as they have the MXM graphics card that allows an upgrade in future. E.g. getting a GT72 with 970m now and upgrade to a 980m (or further, if new cards allow it) in a few years time (980ms are currently £600, but i'm assuming that will drop a bit, say it drops to £400, that's still cheaper than getting a new laptop then).
3. Is there any disadvantage to the older series with 5th gen i7 processor (i.e. i7-5700 , compared to 6th gen i7-6700 ), and with only DDR3 ram compared to DDR4 ram?? Obviously GFX card is the big deal for gaming compared to CPU and ram, but would it make much of a difference??
4. Is there any benefit to getting at 970m card with 6gb of vram rather than the standard 3gb vram?? Everything I've read says "no, 6gb of vram is just a gimmick as it's limited by the graphics chip anyway", but people also say it could be useful for future gaming (again an important consideration for me).
5. As an outside contender, I've occasionally seen refurbished Alienware 17s crop up, within budget, on the Dell Outlet site. One of these had a 980m which is quite appealing, would that be worth the gamble of refurbished (and the shame of owning Alienware)??
Main contenders:
MSI GT72 2QD:
https://www.amazon.co.uk/MSI-GT72-2...8&qid=1461673253&sr=1-1&keywords=MSI+GT72+2QD
Pros: MXM upgradable, good specs, GSync, Win8
Cons: 5th gen i7, DDR3 RAM, slightly cramped KB
ASUS ROG G752VT:
https://www.overclockers.co.uk/asus...tx970m-3gb-gddr5-gaming-laptop-lt-225-as.html
Pros: Keyboard better spaced out, 6th gen i7, DDR4 RAM
Cons: Keys almost invisible, not upgradable, Win10
Gigabyte P57W:
https://www.overclockers.co.uk/giga...r4-256gb-m.2-ssd-1tb-hdd-win10-lt-075-gi.html
Pros: 6th gen i7, DDR4 RAM
Cons: Keyboard looks horrible and recessed, not upgradable, Win10
Cyberpower Fangbook III_BX7-300:
https://www.cyberpowersystem.co.uk/system/Fangbook_III_BX7-300/
Pros: MUCH cheaper, cheaper storage additions, Win8
Cons: Unknown quality, 5th gen i7, DDR3 RAM
Other contenders:
MSI GE72 6QF:
https://www.amazon.co.uk/MSI-GE72-6...&refRID=0Q75SHS2G8JV75KYWDXJ&ref_=pd_cp_147_2
Cons: Not upgradable, Win10, slightly cramped KB
ASUS G751JL:
https://www.amazon.co.uk/G751JL-Not...VHG?ie=UTF8&ref_=psdc_429886031_t1_B015OG3SAS
Pros: Quite a bit cheaper, keyboard better spaced out, Win 8
Cons: Keys actually invisible, not upgradable, 4th gen i7, DDR3 RAM
Any feedback appreciated, especially if it is general principles rather than personal experience (which I know can vary!).
I got myself a G751JT before I knew the G752 was coming out mere weeks later - but don't let that put you off; it's a beast of a gaming laptop. The 3Gb GTX970M is plenty enough to play most new games at high/ultra settings - you only need more than that if you're planning on playing at a higher resolution than 1920x1080.
You might want to have a look at the 3XS LG15 Vengeance G-Sync system. Not at fan of the company selling it, but it has a 15.6" Gsync display and you can get configure it to 980M for around £1350-£1500 depending your choice of capacity for SSD and memory.
Cheers for the replies.
Anthony - why did you go for the ASUS??
Marine - thanks but I want 17 inch.
I had seen a few G751's and really liked them so waited for the G752 to be released as it was December when I started looking and the G752 was on its way so wanted to wait and see what it was like and I was not disappointed ...
very solid build quality and almost silent most of the time and the fans only really kick in when you work it hard in games etc, I really like the keyboard also almost silent and the red back lighting works really well. boots up super fast with the SSD also.
