- 11 Nov 2003
- South London
Hi,
I'm in the market to buy a new laptop to replace my ancient Dell D600.
Budget is up to £1000. I'm after something that will run the latest games, but as I'll occasionally lugging it around on business trips and the like I'd like to keep it down to a 15.4" screen (so I'm guessing a GeForce 8600M should be ample to play crysis etc).
I've narrowed it down to these three options:
1) Rock P670-T7250 £1,000
C2D 2.0GHz CPU / 2GB Ram / 160GB HDD / 8600M GFX / 3yr GTD
2) MacBook Pro £1,350
C2D 2.2GHz CPU / 2GB Ram / 160GB HDD / 8600M GFX / 1yr GTD
3) Dell M1530 £900
C2D 2.0GHz CPU / 2GB Ram / 250GB HDD / 8600M GFX / 3yr GTD
On paper the Dell looks like the best option, but then I have heard more bad things about Dell and more good things about Rock on these very forums.
The macbook intrigues me as I've heard they can run windows games and apps at native speed with bootcamp (is this correct, would the gaming performance be comparable to the Rock or Dell?). Unfortunately it is a bit above my £1k budget, so would need to be appreciably better than the Dell and Rock options to make me consider it.
So what do you guys reckon? Which one should I go for?
Any advice would be much appreciated
Cheers,
Fred
3) Dell M1530 £900
Cheers,
Fred
