Gaming Laptop Advice
5 Nov 2024
Hawick
Hi,
I'm hoping to get advice from you guys on a laptop to buy that will be reasonably priced and will run efficiently for a casual gamer.
Games I would mainly be playing every now and then would be Football Manager, Fifa, State of Decay.
I'm not looking to play anything online like call of duty, would only be offline modes I would be playing.
I'm not looking to pay thousands for something that I will use once or twice a week for a couple of hours at a time.
Does anyone have a recommendation on a laptop to look at or specfic specs I would need to have.
Any advice is greatly appreciated.
Hi, thanks for the reply, would be hoping to spend as little as possible but would be go up to 1k if needed.
That's a bit open ended .
Fur £800 the
Lenovo LOQ NVIDIA RTX 4060 16GB 15.6 FHD 144Hz Intel i5-12450H Gaming Laptop is a good performer but check out reviews and benchmarks.​
This would give around 60fps in cyberpunk at 1080p which is a demanding title.
Fur £800 the
Thanks, will have a look at it now, appreciate your help.
Your welcome.
There so much out there it's trying to find a balance but personally wouldn't get a laptop less than a 4060, hopefully others will chip in with advice . I'll have a look at £1000 laptop and see what's available for the spec.
