Gaming Laptop for around £2,000 or less
20 Nov 2011
Hi Guys
I have ordered the Alienware M17x R4 but Dell have no idea when they will get all the parts at the moment they tell me it won't be before end of Nov but no idea how long after that either!
I want a decent gaming laptop for up to the £2,000 mark, the 2 I have my eye on at the moment are the Clevo Vortex Eite and the MSI GT70-0NE
Clevo
Chassis & Display
Vortex Series: 17.3" Matte Full HD LED Widescreen (1920x1080)
Processor (CPU)
Intel® Core™i7 Quad Core Mobile Processor i7-3740QM (2.70GHz) 6MB
Memory (RAM)
8GB KINGSTON HYPER-X GENESIS 1600MHz SODIMM DDR3 (2 x 4GB)
Graphics Card
2 x NVIDIA® GeForce® GTX 680M - 4.0GB DDR5 Video RAM - DirectX® 11
Memory - Hard Disk
500GB SERIAL ATA II 2.5" HARD DRIVE WITH 8MB CACHE (5,400rpm)
DVD/BLU-RAY Drive
8x SATA DVD±R/RW/Dual Layer (+ 24x CD-RW)
Memory Card Reader
Internal 9 in 1 Card Reader (MMC/RSMMC/SD: Mini, XC & HC/MS: Pro & Duo)
Thermal Paste
ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND (£9)
Sound Card
Intel 5.1 Channel High Definition Audio + SPDIF/MIC/Headphone Jack
Bluetooth & Wireless
GIGABIT LAN & KILLER™ 1202 WIRELESS GAMING 802.11N + BLUETOOTH 4.0
USB Options
4 x USB 3.0 PORTS + 1 x USB 2.0 PORT AS STANDARD
Battery
Vortex Extreme 8 Cell Lithium Ion Battery (5,800 mAh/89.21WH)
Power Lead & Adaptor
1 x UK Power Lead & 300W AC Adaptor
Operating System
Not Required
Total Cost £1,915.00
or......
MSI GT70-0NE
Specification:-
- Processor: Intel Ivybridge I7-3630QM 2.40GHz
- Chipset: Intel HM77 Chipset
- Memory: 16GB DDR3 1600MHz, 4 slots, Max: 32GB
- LCD Size: 17.3" Anti glare full HD 1920x1080 LED backlight
- Graphics: nVIDIA Geforce GTX680M 3D Graphic Card
- Graphics VRAM: GDDR5 4GB
- HDD (GB) 2*128GB SSD in RAID 0 + 750GB 7200RPM SATA
- Optical Drive: BD Writer / Blu-ray
- Audio: Audio Boost, 2 Speakers, 1 subwoofer
- Webcam: HD Webcam(30fps@720p)
- Card Reader: SD(XC/HC)/MMC/MS(PRO)/xD
- LAN: 10/100/1000 Bigfoot Killer E2200 series
- Wireless: LAN 802.11 b/g/n
- Bluetooth: Bluetooth 4.0
Total Cost £2,099.00
The Clevo has a better spec but people say they are fugly, are they really that bad?
There are also some other considerations regarding MSI laptops with cashback.
A bit of advice would be much appreciated :)
Thanks
Hi Guys
or......
Thanks
two gtx 680 will have about about 170% more grunt than the single card...if its working right.
first have a look on the futuremark website for the fastest setups you will see what you need there.
The whole Dell situation with stock is pretty shameful really, to see such a big business fall into that problem is shocking.
Ive also been looking into Clevos and MSI laptops, for my situation where my budget is significantly less i can get a hell of a better spec CLEVO than i can an MSI laptop so for me its a no brainer. Some say the CLEVO is a little fugger but i dont think it looks too bad especially in the elite version your after.
Ive just noticed the CLEVO spec has 2x GTX 680's. So it pretty much boils down to whether you want to sacrifice a GTX card for a laptop that looks better. It a tough choice but i think i would go CLEVO.
- Adam
Thanks Guys
The Dell situation is pretty bad, the worst part is they had various offers on at the time that meant a good discount but didn't have the stock to back them up, poor marketing if you ask me.
The Clevo is a nice machine but I would like to see one in the plastic before I could drop £2,000 on it, I have seen the Alienware and the MSI.
I hate the decision process that goes on in my head, I don't want to regret the purchase I make!
Well this was a pointless exercise for me, I hadn't cancelled my Dell order yet and it is now showing as shipped and the tracking details for DHL are all correct. :)
