Gaming Laptop Help, which one?
27 Jan 2005
West Midlands
Hi all,
Looking for a little bit of advice on a gaming laptop, i have been looking at accquiring one for the last couple of months and in particular the following two, can you please offer advise which one is best value for the £££ or if you know of any better laptops for £1200 or less please pass on the details.
Thanks in advance.
Asus N55SF-S2213V
Processor Intel® Core™ i7-2670QM Quad Core (2.2 GHz, Intel Sandy Bridge Architecture, 6 MB L3 cache, Features Intel Turbo Boost up to 3.1GHz)
Display 15.6" (Non glossy, 1600x900)
Memory 6GB (DDR3 1333MHZ)
Graphics NVIDIA® GeForce® GT 555M with 2GB Dedicated Memory
Hard Disk Drive 750 GB
Operating system 64 bit Windows 7 Home Premium
Optical Drive Blu-Ray (Blu-Ray HD Play back + DVD-RW & CD-RW)
Wireless LAN Wireless (802.11b/g/n Wireless)
Network Card 10/100/1000 Gigabit Fast Ethernet
Webcam Integrated 1.3MP Webcam with Microphone
Card Reader 4-in-1 card reader (MS, MS Pro, MMC, SD)
USB 2x USB 2.0, 2x USB 3.0
Bluetooth Bluetooth® 3.0+HS
Speakers Integrated Bang & Olufsen ICEpower Stereo Speakers
VGA Port 1 External VGA Port
Kensington Lock Kensington lock slot
Charge Time 2.5 Hours
HDMI 1x HDMI Port
Battery Life 3-4 Hours (up to 4 hours with power management)
Weight 2.72kg
Warranty 2 Years Collect & Return
OR
MSI GT780DX
- CPU Intel® Core™ i5-2430M Processor (3M Cache, 2.40 GHz) (3.0GHz Turbo Mode)
- OS Genuine Windows® 7 Home Premium (MSI recommends upgrade to Genuine Windows® 7 Professional)
- Chipset Intel HM67
- 8GB Memory DDR3 1333 MHz ,Slot : 4
- LCD Size 17.3" Full HD (1920x1080) LED backlight
- Graphics nVidia GeForce GTX 570M
- Graphics VRAM 1.5GB GDDR5
- HDD: 750GB (7200rpm) HDD
- Optical Drive: DVD Super Multi
- Audio 2.1 channels speakers, Sound by Dynaudio, THX TruStudio Pro, 7.1ch output
- Webcam HD type (30fps@720p)
- Card Reader SD(XC/HC)/MMC/MS(PRO)/xD
- LAN 10/100/1000
- Wireless LAN 802.11 b/g/n
- Bluetooth Bluetooth v3.0 + HS
- D-Sub (VGA) 1
- HDMI 1 (v1.4)
- USB 2.0 port 3
- USB 3.0 port 2
- eSATA 1
- eSATA/USB Combo N/A
- Mic-in/Headphone-out 1/1
- Line-in 1(line in)/1(line out)
- Express Card N/A
- Modem port N/A
- Keyboard 102-key keyboard by SteelSeries
- Sensor N/A
- AC Adapter 180W
- Battery 9 cells
- Power Management Turbo Battery+
- Dimension 428 x 288 x 55mm(WxDxH)
- Weight (KG) 3.9
- UK Model does *NOT* have backlit keyboard
- UK Model comes with FREE Dirt 3 PC Game
- Steelseries UK Keyboard layout (No Backlight)
- Supplied with Dirt 3, New gaming mouse, 17" Gaming bag
- 2yr Warranty
Pros for the Asus N55SF-S2213V
Price
Blu-Ray Player
Cons for the Asus N55SF-S2213V
Screen Size
Not as powerful as the MSI laptop
Pros for the MSI laptop
Screen Size
Powerful
Cons for the MSI laptop
Price
Lack of Blu Ray player
As you specified gaming laptop the MSI is far better due to the gfx card mate. For that budget you could google clevo UK and see about custom laptops.
Hey mate,
Id be a bit wary about msi as i got myself a msi gx660r 5 months back and just today ive had to arrange for it to go away for repair for three seperate issues which makes msi's build quality suspect as i looked after it extremely well. Its been a brilliant laptop up till now but you dont expect a 1 grand machine to only last 5 months. Also so far theyre customer service in dealing with the repair hasnt been particularly great but with any luck hopefully itll get better as i get further with them.
Thanks Aaron for the heads up, let's hope your machine comes back fine and dandy. What was up with your system?
