Hi there.
Im looking to buy a gaming laptop but wanted to get a few opinions before making a purchase.
First of all is going to be used for gaming, ideally want a 15 inch screen so its portable and the main use will be when the mrs is using the gaming desktop and away from home so i want something as light as possible but still with enough power to play all games currently out.
Here are the options i am thinking out but please suggest any others i may have missed that are similar.
MSI GS60 2PE-060UK Ghost Pro 15.6
http://www.overclockers.co.uk/showproduct.php?prodid=LT-126-MS&groupid=959&catid=1828
light and powerful but have seen many people say there are over heating problem with this machine and if you game with it on your laptop then will burn you?
GIGABYTE P25X v2-CF1 Gamer
http://www.overclockers.co.uk/showproduct.php?prodid=LT-020-GI&groupid=959&catid=1828
2.8 kg but the most powerful machine by quite abit graphically, 2.8 is still quite portable?
GIGABYTE P35W v2-CF2 UltraForce Gamer 15.6
http://www.overclockers.co.uk/showproduct.php?prodid=LT-018-GI&groupid=959&catid=1828
again thin and around 2.2 kg , wondering around over heating here ?
also looked at this which is basically the gigabyte above that is customizable and i could put windows 7 on it..
http://mysn.co.uk/xmg-c504
what is windows 8.1 like for gaming? hated windows 8 when it came out but maybe it has improved. can wondows 7 be put on any of these laptops if required
Like i say i want a 15 inch laptop , portable and one thats not going to have temps going over the roof, what would u recommend from the above or if you have others options then let me know.
