Basically my friend has some latency problems in Counter-Strike.
Me and my friend both live in the same street.
I ping 25-30 he pings 45-55.
I was on Pipex (2mb) and recently switched to IDnet Max (4.5mb) and have been pinging roughly the same throughout.
He was on Pipex (1mb) also and switched to Tiscali (5mb) and is still pinging rather high.
After a switch in Internet and still a much higher ping than mine (despite living 15ft away) we decided it might not be the ISP thats the problem.
We are pretty sure his interleaving is off. He has formatted his computer several times and even after clean installs of everything he still pings high.
He has tried two different routers Belkin realtech and Speedtouch.
His router is downstairs while his computer is upstairs and he connects via a 15M cat5 cable.
Does anyone know if putting a phone socket in his bedroom would reduce latency? since he could use a shorter cable. Also is there any difference between a cat5 cable and a ethernet cable? or are they basically the same cable?
Any help appreciated.
Thanks,
Majik.
Thanks,
Majik.
