gaming machine £1000-£1200...help please.
12 Mar 2013
nottinghamshire
hi, I recently ran a post upgrade or new build. Now my situation as changed a. bit so I thought I would start a new post just to get away from the upgrade side of my old post. Basically what indeed is a pure gaming PC plus web browsing of course.
Would like to consent rate the bulk of budget to the heart of the machine. a reasonable price case would be fine ,not bothered about a high end one. An ssd is a must preferably 256mb, good ram min 8 gig I think, b grade HD would be fine 1tb would be more than ample ,a good cooler and power supply. ......just one thing on the GPU, a bit put off by some off the reports regarding the MSI 7950, which is a shame cos I'm using an MSI 570 ATM but this is a very rare chance I get to spend this sort of cash on a pc so want done sure everything will go OK.... ..Would consider a amd build as long as it still rocks my games.. Many thanks...?.......need a DVD drive and cheap sound card as well
In 2 months intel will show their new cpu's i think u should wait until then and see how much powerful haswell is going to be.
a big thankyou to both u guys for the specs. Just a couple of questions'
1...you both go with an I7 but a lot of posters on here say an i5 is OK for gaming ,is there any reason why you speced the i7 instead of the i5?
2..is there any difference between the his 7950 or the gigabite 7950?...or is it just the one of you guys added a gigabit mobo ?
many thanks
Since your budget is 1K, it will be a waste to go for a Intel i5 3570K, also later on, games may use hyperthreading which the Intel i7 will come handy
I prefer the Gigabyte HD 7950 than the HIS as it has triple fans which will remove heat faster to allow a higher overclock
If you are seriously intending to go Xfire then go for the HIS card. The cooler will dump most of the hot air out of the back of the case as opposed to the Gigabyte card, where it stays inside the case and will be cycled through the top card.
thanks for the explanation chap, just one more thing , both you guys have reccomended fan coolers rather than water coolers, is there any reason for this. Please bear in mind that I'm not that clued up when it comes to most components.
that sounds good advice ,but would the gigabite card still be a good card to go xfire with and apart from water cooling would there be any other way of keeping them cool.
Are you referring to the CPU cooler? If so the the large air coolers offer similar performance to the All-in-one water cooled units (H100 etc) but are cheaper and more reliable.
You can still go Xfire with the Gigabyte cards, but keeping the top card cool may be a problem. You could look at using non matching cards, Gigabyte card on the top and the HIS card on the bottom, but this could* lead to problems and will look a bit odd. Or you maybe try different fan layouts inside of the case.
If you want to get water cooling with a custom loop then the custom PCB the Gigabyte uses may prevent the fitting of waterblocks.
*I'm not sure if using mismatched cards will lead to reliability issues, best have a Google around first to confirm if it is true.
Thanks to all the replys. Two nice system specs to think about. just a quick question, both you guys are specing nice but expensive mobos, is this to take full advantage of the i7 ? . I was hoping to get a 256 mb ssd in the build for about the same budget as you guys offered. Would it be possible to get a cheaper mobo or other parts to make the money back for the ssd or would it be more sensible to stick with what you guys said and invest in another ssd later when i get some more cash. Like i said in my first post im really looking at getting the best bits in my new system for my budget so it will hopefully last.Would not want to risk messing a good system up just to get a bigger ssd.....what do you think?
hi , been away from the pc front for a bit. Unfortunately due to issues at ahome my budget as taken a bit of a dent , im now to £1000 max...
I appreciate all the advice ive been given , but i was looking at similar posts to mine and noticed a spec posted by honosuseri i quite liked but it was abit out of budget so ive tweeked t a bit . For all i know the bits ive put in my not besuitable so please advise, critise were needed.
What ive done is go for better gpu but sacrifised the i7 to an i5.
Ive read some good reports about the sandisc ssd what do you guys think...
Please tweek abit more if you guys think you can improve on my choices
ps the post that im basing my build on is on a post by a guy called skyfall titled £1000 build if anybody wants to look at the original by honosuseri..
Gigabyte ATI Radeon HD 7970 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card Gigabyte ATI Radeon HD 7970 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card £329.99
(£274.99)
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM £179.99
SanDisk Extreme SSD 120GB 2.5" SATA 6Gb/s Solid State Hard Drive - (SDSSDX-120G-G25) SanDisk Extreme SSD 120GB 2.5" SATA 6Gb/s Solid State Hard Drive - (SDSSDX-120G-G25) £95.99
Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £89.99
(£74.99)
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) HDD Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) HDD £74.99
Silverstone Strider Plus 500W Modular '80 Plus Bronze' Power Supply (SST-ST50F-P) Silverstone Strider Plus 500W Modular '80 Plus Bronze' Power Supply (SST-ST50F-P) £67.99
(£56.66)
Zalman Z9 USB 3.0 Midi Tower Case - Black Zalman Z9 USB 3.0 Midi Tower Case - Black £54.98
(£45.82)
Avexir MPower Yellow Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (AVD3U16000904G-2CM) Avexir MPower Yellow Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (AVD3U16000904G-2CM) £49.99
(£41.66)
Thermalright HR-02 Macho CPU Cooler (Socket 775 / 1155 / 1156 / 1366) Thermalright HR-02 Macho CPU Cooler (Socket 775 / 1155 / 1156 / 1366) £39.98
OcUK 24x DVD±RW SATA ReWriter (Black) - OEM OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £19.99
(£16.66)
Akasa USB 3.0 internal adapter cable (AK-CBUB09-15BK) Akasa USB 3.0 internal adapter cable (AK-CBUB09-15BK) £5.99
sorry for the way ive itemed my basket , icant seem to do it like you guys do...
in total it comes to about£1012..
ps idleman, if your still interested in giving me a hand with the build id be most grateful..
Much appreciated Mr honosuseri . Please don't think I'm ignoring your advice but by opting for a cheaper board and power supply like you say and then putting that saving towards a 7970 ,would this be a benefit to the system or in your experience would it be better to stick with the spec you've done for me. I'm just trying to get the max bang for my dollar that's all, once again many thanks.
