Gaming Monitor
22 Apr 2020
please can anyone with their experience, what is the good quality gaming monitor? My budget is £100-£180.
Thank you
due to the huge increase in demand over the last few weeks for just about any monitor! your biggest problem will be getting one, you might have to sit on your hands for a month of two
or in the meantime you could let us know what games you play and what graphics card you have in your PC or dare i say it, what console are you using...there, i said it!
either myself or a number of others will gladly try and help you
Thank you for the response.
Graphic card is Asus GeForce GTX 1650 Phoenix OC 4096MB GDDR5 also have Xboxone and PS4
Hi, you're very welcome
Whether the GTX 1650 can take advantage of a 144Hz refresh rate will depend on the games being played ??
Sorry, I should have asked what games initially but TBH i imagine i may need help from others on here in answering but will do my best
Also, as you have consoles as well what % of your gaming time would you say you are using PC for gaming?
This is the one i'm using and for the money I doubt you can get any better. It has 144hz Freesync and works flawlessly with Gsync too. Out of stock at OCUK but can be had for a little more if you shop around elsewhere
https://www.overclockers.co.uk/aoc-...-widescreen-led-gaming-monitor-mo-053-ao.html
Here is a review
https://www.youtube.com/watch?v=6BVHA2VueOQ
Nice catch! I guess this would be a bit of a unicorn as far as monitors are concerned right now! as i have back orders that will take until July to be fulfilled!
That's not to say that Overclockers are not on the list to get some, i'm sure they are but might have to wait a few weeks
If oday. fancies something a little bit different C24G1 is also worth considering as similar spec and curved, which when looking at the value end of the market is perhaps something you didn't think you would get , supply a little better but not much, hence me getting to spend some time on here!
