I'm considering a new mouse, as after many years of use the soft touch coating on my Logitech MX400 is wearing away where I rest my pinkie. I like the design, which is ergonomic and very similar to the Logitech M500.
I have done a few hours research on what there is out there up to ~£50 that whilst sharing a similar shape has more gaming specific features. I was wondering whether anyone can comment on the build quality and long term durability of the below models? I want something that feels solid, doesn't creak or make any odd noises, and has a coating that won't wear like a pair of cheap shoes. Oh and has a light that can either match the blue LEDs upon my Corsair K70 keyboard or can be disabled completely.
Thank you.
- CM Mizar (quite small)
- Steelseries Rival (have heard negative comments regarding quality and wear)
- Mionix Naos 7000 (unique shape)
- Zowie EC1-A (I believe blue can only be set at a specific DPI setting and can't be disabled?)
- Logitech G303 (no idea when this might be available)
Thank you.
I couldn't recommend it enough. I used to have a naga and in my opinion this doesn't come close, the build quality alone is amazing.
